Send a message via AIM to bholmes
What Megasquirt Forum?
What forum do you megasquirt guys think is the best one and/or what forum are you guys on?
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 06-21-2007, 07:56 PM
meister member
speedracing944's Avatar
MS has thier own forum where you can post questions and such. That is where the gurus hang out. Happy Megasquirting
http://www.megasquirt.info/
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-22-2007, 04:54 AM
meister member
Oppps the link didn't take you to the forums. click on the link and you will notice a blue column on the left hand side of the screen. Scroll down the column until you see
"MegaSquirt Support Forums"
Click on it and you can select the right forum for what type of question you have.
Speedy
Old 06-22-2007, 04:59 AM
Good deal! Thanks Speedy. I joined the forum lastnight. I'm bholmes there as well...I'm creative.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-22-2007, 05:25 AM
There are also the MSExtra(www.msextra.com) forums if you're interested in running MS1/Extra or MS2/Extra.
I'm surprised I haven't seen any one running MS2/Extra, since it might run on our cars without the tooth divider.
-Ian
Stock 1988 951, TT aero wipers
Old 06-24-2007, 11:25 PM
I'll check it out. Thanks!
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-24-2007, 11:54 PM
cold starter
JustinL's Avatar
-Ian
The new B&G beta code will do it too. The problem is that we still need the second VR circuit for the reference sensor.
I'm planning on doing a plug and play system by the end of the summer and I'll make sure I document it for anyone else who wants to try it.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 06-25-2007, 01:09 PM
I think I saw your post on the microsquirt forum about that?
I've been thinking about Megasquirt for a while, but I'd need to be able to pass smog with it, so it needs to work well and I want a fairly clean install so the techs don't notice.
Old 06-25-2007, 01:37 PM
cold starter
JustinL's Avatar
I think a microsquirt board is small enough to fit into the stock DME box, which would make for a super stealth install. The only thing you'd have to worry about the inspectors finding is the IAT sensor. On an n/a even that could be concealed in the old AFM box if you wanted to reuse the AFM connector and wire to serve a different purpose.
Old 06-25-2007, 02:08 PM
The plug and play sounds quite nice. Keep us posted on your progress, I am leaning pretty heavily towards doing a megasquirt system for my turbo conversion so that makes things sound even better.
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 06-25-2007, 06:06 PM
Yeah with all the people frying/turning up with bad ECUs there ought to be an alternative to the stock 9201(?) DME; this, and the dwindling supply of good DMEs out of junkyards.
-A write up of installing a megasquirt into a 944 would be gold.
Old 08-01-2007, 08:36 PM
Indeed! any of you MS veterans want to contribute?
Brian
'86 944 NA
'86 Chevy C10 425hp
Old 08-02-2007, 02:52 PM
ae1969's Avatar
Send a message via ICQ to ae1969
I have thought about it........... but everytime I look at the binder of information I have piled up it kinda turns me off.
I even have a few sheets showing the details of making the harness and how to plug it right into the engine bay plug.
Maybe in a cold winter day...... I will put it together.
Bottom line. ANyone contemplating this has to get acquainted with the MS site.
75% of the info is there.
The other 20%......... wiring routing, sensor options, timing and fuel maps, tips and tricks is out there on the net
The final 5% is what will get the car started and running well. That is car and enthusiast specific.... it is not rocket science by any stretch of the imagination. Common sense and some mechanical ability is all it takes..
Winter is around the corner no upgrade plans for the car this winter so I should have some time.
But then again we might be squirting JustinLs NA with that microsquirt ..........
If anyone goes down the path I am sure we can all lend a hand when they get stuck.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-02-2007, 06:37 PM
I'm down with building the ECU,
-I'm on summer break and have been considering building one just for fun. I'm thinking the Original MS-1 processor with the board version 2.2 or something.
-Whatever I put decide to put it into, it will indefinitely be older, so the 40 pin connection is what I'll probably build. I will build whatever fits a '44 best though.
Old 08-02-2007, 08:47 PM
cold starter
JustinL's Avatar
The plan for the N/A is to do a microsquirt setup once it's available. I'm on the waiting list for the first batch, which should be available in the next couple weeks. Once it arrives, it's a matter of getting it installed, running, and then tuned.
I see it as an open source project, so I'll document and photograph all the steps.
Old 08-03-2007, 06:56 AM
Sounds good.
Was there some group buy or some other sort?
How is the one you ordered different/specific to the '44?
Old 08-03-2007, 06:19 PM
