Politically Incorrect
Evaporator Leak Fix
OK, so I spent about $17 and got my air conditioner working. Nice cold air. Everything is great until I notice mold growing on the passenger foot-well carpet. It is absolutely soaked!
Somebody here said the drain line could have come undone - so I checked - it was. Now this thing is made of hard plastic tubing and there was no way it was going to go back on. So I cut off the elbow and replaced it with some 3/8" hose and an elbow fitting. All is well again.Note that for the 924S, and probably the 924 models as well, the drain is in the passenger foot-well because the evaporator core is under the glove-box. I'm pretty sure all the 944 models have the drain behind the radio because the evaporator core and heater core are in the same air handling unit behind the center console. Pretty sure.
Edek '87 924S '91 535i |
Thanks for the heads up
Why'd you cut out so much foam? Was it infested too, or was it just to make the job easier?
1978 El Camino 350 4 barrel 3-speed automatic The most expensive Lawn Ornament in my county. 1988 Thunderbird Turbo coupe 5-speed manual 2.3L V4 (The Dirty Bird) 1942 Willis Army Jeep 3-speed manual (you can't get it stuck: I dare you to try!) 1987 924S (My Little Silver Money Eater!) 5-speed manual 2.5L SOHC |
Made the job easier. I removed the tube, modified it on my workbench and reinstalled it.
