-   -   removing locking lugnut with no key (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/360265-removing-locking-lugnut-no-key.html)
vancity944 08-03-2007 08:41 AM
Yup, I lost the key. Any tips for removal from those of you who wouldnt admit you've done the same lol.
Thanks in advance !!!!!!
87944turbo 08-03-2007 08:42 AM
Mine only worked about half the time so I drilled them out.
Dantilla 08-03-2007 08:58 AM
I've bought auction cars that came with no key. A 19mm or 3/4 circle cutter will shave off the nut without damaging the lug, if done carefully.
flash968 08-03-2007 09:14 AM
snap on makes a tool that will remove them
i refuse to use locking lugs - i don't worry as much about people stealing my wheels as i do the problems with correct torque, and the lock screwing up, or the key getting lost - besides, that's what insurance is for
Techno Duck 08-03-2007 09:14 AM
A chisel on the face of the key hole works well :). The old style locking lugs are basically garbage.
vancity944 08-03-2007 09:21 AM
thanks
Is everybody playing hookey from work today lol. Thanks guys.
Eldorado 08-03-2007 09:34 AM
if I wake up and my wheels are gone tomorrow, I'll know who to come after ;)
many944s 08-03-2007 09:41 AM
I used to be a locksmith, and they are VERY easy to pick!
Actually you can pick them with 2 bobby pins (found in most womens purses)
Hope it helps!
-Nick
OnTheRun2 08-04-2007 09:43 AM
When I bought my car, the PO didn't have the wheel lock key.
I also used a locksmith. It took 10 min. to pick the lock and make a new key. And only cost $25.00.
Had them make a few keys, just in case I loose one.
