-   -   i finally got the koni struts installed (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/361307-i-finally-got-koni-struts-installed.html)
nynor 08-10-2007 05:25 AM
that i purchased last christmas. there is a marked difference with cornering. the ride doesn't seem a lot harsher, maybe a little. i can't wait to autocross it.
Dave L 08-10-2007 06:37 AM
did you do front and back? I recently did mine and have my first autoX this sunday. The ride shouldnt be harsher unless you also upgraded to stiffer springs. I find my car is "more connected" to the road if that makes sense.
flash968 08-10-2007 07:15 AM
just don't make the all too common mistake of dialing them up too much, thinking it makes things stiffer - it doesn't - it only increases the bump - dial them for your spring rate - the stetting for stock rate would be about 1 turn from full soft
nynor 08-10-2007 07:21 AM
yep. i had a local shop install them. the owner races porsches and set it based on the other components i have.
