High Fuel Consumption
Good Evening, 1980 924 2.0 non turbo, The car is ok no problem on hot or cold start , timing perfect no jerks idle at 900 very stable. but consume fuel eg. 5 litre for a 20 km . would appreciate any suggestion from you guys out there.
my hunch is leaking injector but the is no black smoke. btw I live in kuala lumpur malaysia and there very few 924 and parts are a real problem.
Thanks again
Old 11-13-2007, 03:07 AM
Quality
phoenix_iii's Avatar
Porsche Crest
Welcome to the board.
A good investment and possible cure is a new O2 sensor. It is probably due, and could be the silver bullet for your problem. Also make sure the existing wiring is okay, etc. =)
Old 11-14-2007, 07:21 AM
jackpine savage's Avatar
Thanks again
I think you could get the O2 sensor through Pelican? Who's the shipper in your neck of the Malaysian woods? DHL, UPS, FedEx? Just curious...
When in doubt,
don't part it out.
Old 11-14-2007, 10:19 AM
Thanks a lot guys, the car comes with k jetronic without lambda sensor, Would appreciate some advise on what to do next, or is this normal fuel consumption for 924 eg 5 liter for 20 km journey of normal driving.
Shipper, we have Dhl ,Ups and Fed Ex , mechanic here are suggesting a swap with carb.
Btw the picture attached is not the car it was a mistake.
Thanks again Guys
Old 11-14-2007, 11:56 PM
We had a 82 924 that ran without the lambda (open loop). The electronics were too far gone. Mileage was 18-22 miles/gal. How does this compare to 4 km/liter? I'd have to look up the conversions.
Pull the plugs. Are they all evenly fouled from running rich? If one cylinder is worse you may have an injector issue. It is very easy to test the injectors, the proceedure is in Haynes.
K-Jetronic is essentially mechanical injection. It isn't as good as the newer stuff. People have converted to carbs. Go to the 924 site and do a search, they talk about it there.
Bosch sells a very good book about the K-Jetronic. If you are going to do your own work it is a good starting point.
Good luck,
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 11-15-2007, 06:34 PM
Thanks Jon , will work on the injectors as per the Haynes manual, on the conversion its on the high side.
Thanks again
Old 11-16-2007, 02:12 AM
You would probably do better posting on the 924 site. Thats where all the knowledge is for the 924. the 924s/944 is a different animal.
Jon
87 924S
82 924-Gone.
Old 11-17-2007, 09:40 AM
