jezza944's Avatar
Noisy brakes
I've had my '84 for just over 2 years now, and the rotors and pads were replaced not long before, according to the records. I've only done about 16000 kms/10000miles in her. Ever since I've had it I have a very noisy binding sound from the rears when reversing, and unless I break hard, I get a loud squealing, mostly the front when pulling up slowly and especially when she's cold. Is this normal, or do I perhaps need to remove the pads and put some of that pad goop, forget what its called, on the rear of the pads? I have looked at the pads, and they still look like new. While I drive like we should drive our gems, I rarely brake very hard, using the gears like they should be. Anyone had this problem and fixed it?
Dave Jezza
http://www.pelicanparts.com/gallery/jezza944
1984 944na Krystalgrun (Crystal Green)
Old 08-20-2007, 06:11 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I had the same issue on the front of my car, R&Ring the calipers, cleaning and lubing the sliders, and a thin coat of anti-seize on the back of the pads ("pad goop" would probably work better) fixed it.
can't comment on your sound when backing up; that doesn't sound right. Is your e-brake adjusted too tight?
nate
1988 944... and a bunch of other cars
Old 08-20-2007, 06:12 AM
jezza944's Avatar
Good thought, the e-brake, but I can push her around the workshop ok when I'm too lazy to jump in and start her. But I guess that could be binding just a little. Thanks.
Dave Jezza
Old 08-20-2007, 06:17 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
My rear pads were squealing really bad a couple months back. It was a horrible, loud, glass-shattering squeal that wouldn't go away. The pads had like 80% life left on them, so I knew it wasn't the wear pads. I never did figure out exactly why the pads were making that noise. I just got new pads, resurfaced the rear rotors (they were also newish) and laid on a lot of anti-squeal stuff. They're good now.
Before I changed the rear brakes, I thought it might have been my e-brake, but it wasn't. I changed the shoes and that didn't help. Hope you sort it out, but it sounds like we had the same problem, just different axles.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 08-20-2007, 08:10 AM
