Need odometer help.
The odometer on my 86 stopped working so i removed the gauge cluster and followed the steps on rennbay....i get in there only to discover that all the gears are intact and in excellent shape...so the question is is there anything else i need to check or is there something broken out side the odometer and yes the speedo worked when i took this all apart.
could be the motor that drives the worm gear or the circuit board that drives the motor.
Good luck, George Beuselinck |
is there a way to check either of those?
