Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Life span of thermostat and ..
What is the normal life span of a thermostat?
And is there any way of testing the thermostat without removing it from the car? Reason being is that I think it may be bad..Knowing would be better.
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 09-01-2007, 12:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Greasy Member
many944s's Avatar
Bad as in not opening, or stuck open, intermittent?
Of course, if it takes forever for the car to come up to temp, of if it never comes up to temp, it is stuck open...
If the car runs hot, and the radiator is still ambient temp to the touch, the thermo is not opening.
Intermittent problems can vary.
I've see t-stats last for a as little as a month, and as long as 20+ years!
There is no guarantee!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 09-01-2007, 09:20 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Car is running hotter than normal after changing out thermo switch, testing fans, bleeding system, etc. Granted it has been very hot here but the fans normally had kept the temp in check.. Engine temperature hit the hot mark yesterday and fans did not seem to help all that much. Yes, the fans are working..
-Nick
3-924's (Sold)
1967-912 (Traded)
Old 09-01-2007, 10:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Greasy Member
many944s's Avatar
Ah, you changed out a thermo-switch...
The one on the head for the DME, or the one on the radiator for the fans?
If it is the one on the rad for the fans, it may be actuating at a hotter temp than it should to kick on the fans. How long has it been since you flushed out your radiator?
Another ugly question is, have you checked the rotation of your water pump?
How long since the pump/belts have been replaced?
I have seen a 944 with the belts put on so tight, the bearing for the pump began to cock-sideways in the pump housing which reduced the flow, and caused the car to overheat. Once removed, a business card couldn't fit between the impeller and the housing while the other side had almost 3/16" clearance!
Just examining all possibilities..
-Nick
Old 09-01-2007, 11:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
I replaced the fan thermo switch.
I didn't know about the other..Is this an early 944 situation? And should this also be changed periodically?
Last flushing was 3 years ago when I replaced all the cooling system hoses , fan switch, thermostat and put on a late model bleeder and a turbo radiator.
3-924's (Sold)
1967-912 (Traded)
Old 09-02-2007, 12:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Greasy Member
many944s's Avatar
There are different thermo switches out there with varying temps for switching on the fans. If everything was working fine before swapping this out, I'm betting the switch you installed is a higher temp switch.
Though, it couldn't hurt to flush your coolant either!
-Nick
Old 09-02-2007, 01:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
I actually was having a problem with the fans not running. Got that fixed but now its running hotter. I will probably flush the system and replace my thermostat. And maybe try my old thermo switch just for fun!
3-924's (Sold)
1967-912 (Traded)
Old 09-02-2007, 05:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
This is an update on my cooling problem.
When I initially replaced my thermo switch, I also replaced my 3 blade fan with a 6 bladed one.
What I didn't notice is that I had switched the positive for the ground, making the fan run in reverse. This in turn caused no fanning of the radiator. So if you still have a problem with non cooling , you might want to verify the polarity of the electrical lines to the fans. In the early 944, there is no "plug" for the 3 bladed fan, just a positive and ground wire that slip on.
3-924's (Sold)
1967-912 (Traded)
Old 11-04-2007, 08:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
