Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Those w/painted intakes....?
What paint did you use when you painted it? Same goes w/cam cover. Thanks!
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 08-31-2007, 11:05 AM
Not Special
Most people actually get them powdercoated, I'd think. That's what I'm going to do,
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 08-31-2007, 11:54 AM
Misunderstood User
I painted the "PORSCHE" on my cam tower. There are other ways, I'm sure but this is what I did:
Clean the surface: Used a wire brush attachment on my drill. Wiped everthing down with degreaser.
Taped everthing off. Used Gorilla tape. Worked very well.
Sprayed the area with high temp clear. The stuff the use for automotive applications. What this does is seal off any parts where the tape did not stick well. It prevents the paint from bleading underneath the tape. An old placstic model painting trick.
Used flat black high temp paint to spray the letters. Let dry over nite. Sprayed the area with high temp clear.
I'm happy with it. I did a similar job on my son's 525i valve cover.
To do an intake: don't you need to remove it from the engine?
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-31-2007, 12:01 PM
That Guy
Techno Duck's Avatar
Duplicolor high temp spray paint from PepBoys...
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-31-2007, 01:31 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I used 1200 degree high temp paint for my intake and cam cover 2 seperate times. I never put the clear on but I regret that. I have not had any problems with peeling or bubbling, but the paint does chip easily and gas will wash it away without much hassle. It looks good though.
-Greg
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 08-31-2007, 02:47 PM
idesign635's Avatar
Send a message via Yahoo to idesign635
Polished intake, used black wrinkle finish on valve cover.
94 968 Polar Silver/Black, LSD, 6 speed, Short Shift, Kenesis K58's, Adjustable Konis, M030 Swaybars, Dynatech Strut Brace, Design 1 Racing Lower Strut Bar, Air Box Mod, B&B Catback, RS Barn Chip, Big Reds
86 951 Black/Black Lindsey 3" Exhaust, Lindsey DP Wastegate, Lindsey Black Knob, 3 Bar FPR, MaxHP Chips
Old 08-31-2007, 03:24 PM
Will work for parts
944 boy's Avatar
now that's hot!
Old 08-31-2007, 06:14 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
No joke that's crazy sexy!
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 08-31-2007, 06:55 PM
thats just sexy right there,
1987 944 n/a
Old 08-31-2007, 09:35 PM
924Sman's Avatar
Thanks guys!......Nice pics too!
Dal
Old 09-01-2007, 05:30 AM
