Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
high idle when very hot out
I haven't posted about this "problem" before because it happens so infrequently, but when it is very hot and humid out (88 degrees or hotter), once my 951 is warmed up the idle occasionally will not drop below 2K. It will do this at a few stop lights, but then will end up dropping back down to around 1K.
This problem does not occur at all when it is less than 85 degrees out. Am I looking at some kind of temp sensor?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 08-31-2007, 03:45 PM
same prob here, mine idles high enough to drive itself around,but only when hot, gets about 1600 rpms, its kinda like a cruise control,
1987 944 n/a
Old 08-31-2007, 09:36 PM
Writer/Teacher
CJFusco's Avatar
bump
Old 09-01-2007, 07:19 AM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
CJ i had a similar problem with my NA, im not sure exactly what it was but it did go away after that big project i did last winter. I think one of the few things it could have been was
1) DME temp sensor
2) ISV
It was similar to yours, i would come up to a stop sign or such, the idle would just sorta hover around 2K for a little while then really really slowly come back down. the problem was very infrequent. but i havent seen it since...
1995 993 C2
Old 09-01-2007, 07:30 AM
winter-hater club member
nynor's Avatar
mine does this also, but it has to be closer to 105F outside. it'll creep up to about 1500, slowly come down, repeat.
"COOL PRIUS!" - Nobody Ever
Old 09-01-2007, 08:59 AM
adrian1's Avatar
My dads 951 does the same thing qhen hot. It goes up to like 2k rpm. Haven't fix it though.
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 09-01-2007, 09:23 AM
Writer/Teacher
CJFusco's Avatar
I'm thinking it must be a temp sensor, but today when I had some free time before work, I cleaned all the electrical connections for the throttle body and flow meters, just in case.
Old 09-01-2007, 12:18 PM
Politically Incorrect
onZedge's Avatar
Just throwing things out here:
- heat soak related vacuum leak (I don't recall your mention about changing any lines since you bought "Ruby")
- does the throttle fully return to the stop when this happens
- is the TPS adjusted correctly
PS: 88 deg F is hot? It was over 100 here for about three weeks! Of course I was in CT during this southeast heatwave and enjoyed temperatures that averaged 5-10 deg cooler than normal.
Edek
'87 924S
'91 535i
Old 09-01-2007, 02:01 PM
Writer/Teacher
CJFusco's Avatar
It may be unrelated, but I advise everyone who has this problem to do the following:
Yesterday I swapped out a bad cruise control motor for a "new" one. When I got it back together I took the car for a drive, and once it got to standard operating temp, the idle climbed to 2K - in other words, the problem reoccurred, despite it not being incredibly hot out yesterday (around 84 or 85).
I got back under the hood and loosened the throttle cable that attaches to the cruise control motor. Problem solved. I guess I won't know if this was the culprit unless we have any more 90 degree days this year (getting unliklier by the day), but it's worth a try
Old 09-02-2007, 12:00 PM
