-   -   WHich way for the idle control sensor? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/365596-way-idle-control-sensor.html)
jlorda 09-05-2007 03:26 PM
Which way does the idle control sensor go on a 86 944 engine?
djnolan 09-05-2007 04:50 PM
If you are talking about the idle speed control solenoid. It is should be with the arrow pointing towards the intake manifold port underneath. At least on a 85.5 944 N/A it is this way. It is a tight fit to get the clamps tight.
