-   -   Front end question '84 944 (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/365728-front-end-question-84-944-a.html)
bobe 09-06-2007 12:31 PM
Every time I hit a good bump in the road, my front wheels feel like they
bounce several times and the car briefly wanders for a second or two. Car does track nice and straight otherwise. Are the front struts gone or is it the steering
rack. How do I check it out myself.
Dave L 09-06-2007 02:15 PM
sounds like struts to me, I would look for leaks and do a "bounce test" although I though my shocks were fine until I upgraded to Konis. How many Km's on the car?
bobe 09-06-2007 02:18 PM
struts
180,000 kms suspension is very firm no leaks on inspection.
svandamme 09-06-2007 02:33 PM
the control arm ball joints, or bushings perhaps??
earlr85944 09-06-2007 04:09 PM
check for leaks at the front struts and bounce the front suspension:
lift the front end off the ground and use a pin to lock the rack in place or have
someone hold the steering wheel and check for play in all mechanical wear areas by moving each wheel left to right and observing play in;
steering shaft links, tie rods inner (mostly) and outer,
ball joints - put a bar under the wheel and try to lift it;, and for bearings grab wheel from top to bottom and try to tilt it in and out;
change all found questionable, then get an alignment
