Graduated User
conkeytonk's Avatar
Time for new tires?
It’s about time for tires. Will a 225-50-15 fit on the OE Stukes (sp?), phone dial wheels? First owner had 215-60-15’s on her. Nice prices on the Falken’s from Edge Racing but I wonder about them.
Randy
1977 Scirocco Rebuilt 1.7L Stock Grey (Totaled)
1979 Scirocco Built 2.0L Stroaker Blue (Pilfered)
1979 Scirocco Built 1.8L Rust Bucket Tan (See ‘ya)
1982 Scirocco Rebuilt 1.7L Garage Kept Gold Daily Driver
1987 944 NA Rebuilding 2.5L One Female Owner Grey Weekender
Cruising to a conkeytonk in my Scirocco on steroids
Old 09-11-2007, 10:05 AM
Ornery Bastard
Phone dials aren't Fuchs (pronounced roughly "fukes") wheels.
A 225/50 will have approximately 866 revolutions per mile.
A 215/60 will have approximately 826 revolutions per mile.
You will make your speedometer and odometer read approximately 5% fast (i.e. when the odometer says you've traveled 105 miles, you will only have gone 100) if you use the 225/50 series tires.
They should physically fit though, since they are shorter, and since the optional wheels with the sport package were 225/50 R16 which means that the width should be OK.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 09-11-2007, 10:50 AM
Graduated User
conkeytonk's Avatar
Okay, thanks Aaron...great information.
Randy
Old 09-11-2007, 11:03 AM
Ornery Bastard
You're welcome. And thinking about it a little more, if you're OK with the odometer discrepancy, then it might be a good swap actually. Especially if you plan to autocross the car since the shorter sidewalls will have less flex and you'll get better cornering response.
Old 09-11-2007, 11:51 AM
Graduated User
conkeytonk's Avatar
No, the rotation differential doesn’t bother me; I’ll remember it though when calculating speed. Again thanks.
I’ve always cherished a good handling car so the 50-series it shall be. I like the look as well.
Does anyone know about the Falkens (with a 360 tread-wear index…a bit high). I’m also considering Yokohama with a 280 tread-wear index.
Randy
Old 09-11-2007, 12:06 PM
I Had To Replace The Tires On My 944, Went With The Yoko Es100 225/50/15 Rear , And 205/55/15 Front. The Grip Is Inspiring, And So Far They Have Worn Very Evenly. The Specs On The 205/55/15 865 Revs Per Mile, 7.5 Inch Tread Width, 24" Diameter. Specs On The 225/50/15 886 Revs Per Mile, Tread Width 8.3 Inches, 24" Diameter.
Old 09-18-2007, 09:48 AM
Graduated User
conkeytonk's Avatar
How about that! I decided on the 225/50/15 Yokohoma Es100’s for all four a few days ago. Had an ancient set of Yoko’s on one of my Sciroccos and swear it was the best tires I have ever used. Why do you run a different size from front to rear?
Randy
Old 09-18-2007, 11:42 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Isn't that what they had stock? Staggered setup?
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 09-19-2007, 07:38 AM
Tires
I recently replaced my stock 215-60-15's with 225-50-15's. They fit just fine, and have less flex in the side wall. I really like them. Some people run thinner tires up front. I was told this is done to prevent over stear in the turbo cars. Don't know for a fact though. I went with the same width front and back, that way I can rotate the to prolong tire life. Hopre this helps.
Old 09-19-2007, 08:55 AM
Ornery Bastard
Originally Posted by steve rappath View Post
I recently replaced my stock 215-60-15's with 225-50-15's. They fit just fine, and have less flex in the side wall. I really like them. Some people run thinner tires up front. I was told this is done to prevent over stear in the turbo cars. Don't know for a fact though. I went with the same width front and back, that way I can rotate the to prolong tire life. Hope this helps.
Yup, power-on oversteer in the turbo can be a problem, even with the staggered tire sizes. Found that out once again yesterday coming out of a 35-40 mph corner in second when boost came on before I had the car straight again and the back end started to come around.
The NA cars came with the same size tires on all wheels.
Old 09-19-2007, 10:02 AM
