Adjusting belts- Help
Started to unbolt the upper and lower plastic housing that covers the timing belt. One bolt just turns, and does not unscrew out. What can I do to get this to unscrew correctly?
This screw goes into another plastic piece.
1985/2 - 944 Good ten foot car
Old 09-22-2007, 10:47 AM
Send a message via Yahoo to bobp53916
Is it one of the bolts that screw the 2 plastic covers together? I had the same thing happen when I removed mine but it was one of the bolts that screw the 2 together, I just took them both out as one piece and dealt with it when I got the covers out. If its one that screws to the inner piece then I would say you would need to hack the bolt head off.
Bob
1985 944 N/A
1992 Formula Firebird (sold)
1997 Sebring LXI
1998 Ford Expedition
1983 944 (parted out) 1979 924 Turbo (sold)
Old 09-22-2007, 10:59 AM
Greasy Member
many944s's Avatar
Sounds like the fixed nut in the rear cover is turning inside the plastic. Your best option is to carefully cut a "V" in the edge of the cover and remove the nut from the rear cover as you pull off the front cover.. If you do this carefully, you can use a bolt, nut, and a couple of washers to hold it together when you re-assemble it. It sucks, but it happens fairly often, just make sure you don't over torque the bolts when you put them back in, or you may have to cut another one out next time!
Good luck!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 09-22-2007, 11:52 AM
Thanks guys.
Old 09-22-2007, 12:12 PM
meister member
speedracing944's Avatar
Just like many944s said.
Make sure to just snug them up when you reassemble.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-22-2007, 02:03 PM
