fast924S's Avatar
Send a message via AIM to fast924S
oil pump drive gear ?????
hey guys. Im in the middle of installing my oil pump. Per clarks garage it says if the oil pump drive gear has a ridge on it from wear then replace the gear. I have a very slight ridge that my finger nail barely grabs, You think it will be ok or should I replace it?
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-22-2007, 01:12 PM
fast924S's Avatar
Second question, I was looking at the Pelican parts diagram of the oil pump and its parts, the gear is #3 just incase you didnt know, Put I noticed at the end of the shaft the show a o-ring, Mine didnt have this when I removed the pump, I would think that o-ring would get crushed by the crank pully. Is the o-ring correct or a mistake its part #4
Link to diagram
http://www.pelicanparts.com/PartsLookup/HTML/924S_USA_KATALOG/104-00-Frame6.htm
Old 09-22-2007, 01:18 PM
Yes, all 944 motors have the o-ring (it is the same part as the water pump block-off plate o-ring).
Yes, if the oil pump drive is has any sort of ridge, replace it. Make sure you get the correct one.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-22-2007, 02:17 PM
fast924S's Avatar
So to get this right, The o ring goes on after I put the drive gear in
Old 09-22-2007, 02:42 PM
fast924S's Avatar
So it should look like this correct
Sorry for all the questions, But clarks garage doesnt talk about it nor does haynes manual.
Sorry pics from cell
Old 09-22-2007, 02:54 PM
That Guy
Techno Duck's Avatar
Yes thats right. Make sure you put on that thrust washer also.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-22-2007, 04:29 PM
fast924S's Avatar
OK thanx, Thurst washer is this guy #21
http://www.pelicanparts.com/PartsLookup/HTML/924S_USA_KATALOG/102-00-Frame6.htm
Hey does anyone know where I can get the oiler cooler alignment tool?? In the past I just eye balled it and it worked fine, But I would like to try it the right way LOL
Old 09-23-2007, 08:35 AM
Please make sure that the oil pump drive is seated in the housing. Give it a turn until in drops into place. Also make sure the pulley nut is torqued to the correct specification.
dlp
Old 09-26-2007, 02:49 PM
