-   -   Replaced Dash, Dome/Trunk Light Not Working (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/369434-replaced-dash-dome-trunk-light-not-working.html)
exitwound 09-28-2007 01:35 PM
Door chime works but the dome light will not work (in any position) nor will the trunk light. What may I have done? Is this related to the glove box light in any way? During the glove box removal (forgetting to disconnect the battery) we blew the glove box light inadvertantly.
Aslet 09-28-2007 02:14 PM
Did you blow a fuse too? I know I have blown a few fuses messing around without disconnecting the battery :-P
livewirevoodoo 09-28-2007 07:07 PM
Glove box light should not matter. Check your rear hatch struts wiring connection (for the defroster grid)... a bad ground on those cold cause the dome light to malfunction while a door is open, but in that case the dome light switch should still work when switched to the "always on" position. Check bulb, fuse and wiring.
