Cleaning engine parts
hey guys, i want to clean out an engine block and all the parts along with it, individually (I am rebuilding). What should I use? Varisol bath? or what other type of parts cleaner that won't damage anything?
Dan
'84 944 - Under construction
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 09-29-2007, 07:24 AM
ae1969's Avatar
Send a message via ICQ to ae1969
That will work fine...
I use a bath where I can...... but for larger pieces I will apply varsol and scrub with a brush.
Otherwise a quick shot of brake clean ...
I usually follow with blowing out the parts with compressed air..
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-29-2007, 08:33 AM
I think i need to get a tub large enough for the block to fit in. or maybe i'll just find an engine rebuild shop somewhere in the city and see if they can clean this engine block/head and everything else for me. What do you guys do when you rebuilding and need to clean everything out?
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 09-29-2007, 11:50 AM
Politically Incorrect
onZedge's Avatar
Check your local laws, but...
...try a car wash with the "soap" and then "rinse" setting. Some car washes even have a "degreaser" setting which I would use first. Some local laws prohibit doing what I suggest though.
Edek
'87 924S
'91 535i
Old 09-29-2007, 12:10 PM
Send a message via AIM to deekay911 Send a message via Skype™ to deekay911
Your wife/girlfriend won't like it, but the dishwasher is good for parts small enough to fit in there.
1996 993 C2
1995 968 Cab
1976 Norton 850
Old 09-29-2007, 12:38 PM
dude this would be worth to do just to see a look on my wifes face when she opens our dishwasher and finds misc engine parts in there. but i guess it would work for pistons and other stuff, soap was made to degrease and heat will evaporate all water off the parts before they rust.
any other ideas guys?
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 09-29-2007, 02:20 PM
Greasy Member
many944s's Avatar
I have a 27 cubic foot (3x3x3) parts steam washer that works wonders on parts and blocks alike. Put block in cabinet, turn on unit... 30 minutes later, take block out and blow off with compressed air. After that it's ready for lube and rebuild.
If it is a iron block, I usually put a little simple green in with the water in the supply tank. The entire process uses about 20 gallons of water, and 2 lbs of propane. All in all, alot cheaper than taking it to the local machine shop!
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 09-29-2007, 03:32 PM
27 cubic feet washer is nice, but i do not have an access to one so i have to either improvise or find ways...
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 09-29-2007, 06:20 PM
Used & Abused
medium plastic garbage can, 5+ gallons of solvent, an old fuel pump, some hose, and a battery charger.
That is my poor mans parts washer but it's worked for years now.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 09-29-2007, 07:37 PM
Nobody Special
My local shop steam tanked my block for $35 as part of head and crank work I was having done. It was easiest for me and came out great. I just pressure wash the other stuff like the X-member, mounts, control arms at home. A large parts washer would be great if I had the room for it.
Old 09-30-2007, 08:11 AM
would it be safe to just spray on a lot of engine degreaser on your motor let it sit and just pressure air it off?
944 fan
88' 944 n/a
Old 09-30-2007, 09:15 AM
onZedge's Avatar
Degreaser is fine. Follow the directions on the can. Finish it off with plenty of soap and water. Most of the engine parts are aluminum - so no rust. Hey, I've got a better idea! Why not take it to a car wash with a power sprayer? Why the hell didn't I think of that before?
Edek
'87 924S
'91 535i
Old 09-30-2007, 02:46 PM
well i thought you werent supposed to get your motor wet or theres somthing your supposed to not get wet
944 fan
88' 944 n/a
Old 09-30-2007, 02:57 PM
onZedge's Avatar
I thought you said you were rebuilding it. If you are, you have it all apart - right? You obviously don't want to wash anything electrical.
Edek
'87 924S
'91 535i
Old 09-30-2007, 03:01 PM
yeah everything is apart, just needs cleaning from old sticky oil.
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 10-03-2007, 06:26 PM
dweymer's Avatar
Don't use the dishwasher! I did when I rebuilt my 911 and it stained the interior. I had to buy a new one ASAP. Also, check the degreasers label first, many will cause corrosion on aluminum. The citris based ones worked very well for me.
Donnie
Currently Porsche-less.....
Old 10-03-2007, 08:20 PM
I just did my engine with Simple Green and a soft brush. Spray everything down with simple green and let it stand for a few minutes. A few strokes with the soft brush and hose it off. A few really nasty spots required a second shot, but everything came clean. A blast of compressed air dried everything and I was good to go.
Old 10-04-2007, 02:50 AM
