Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
87-88 Koni inserts question
OK, so I am pretty close to just ordering the Koni inserts for a full front suspension rehab... I have a couple strut bearings laying around so I won't be buying those. However I do need bump stops and boots... on Paragon's web site I see they sell Koni brand bump stops that appear to not be used with boots. Should I buy those? Or will the stock bump stop/boot combo work on the Konis as well? I would prefer to go stock as this is an all-weather driver (got a set of snow tires ready to go in the garage.)
I'll probably pop for the complete assemblies already done from Paragon as I unfortunately find myself very short on quality wrenching time
thanks,
nate
1988 944... and a bunch of other cars
Old 10-04-2007, 05:47 PM
Misunderstood User
I have an 83 that I has new Koni inserts. I also replaced the stock springs with Weltmiester 200 lb springs. This lower the car about an inch. I kept the stock boots and bumpers with no problems.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 10-05-2007, 08:27 AM
flash968's Avatar
depends on the condition of the bumpers - if they are cracked and/or spongy, they need to be replaced - which one to replace them with is somewhat subjective, depending on how fast you want the bumper to compress - they come in different durometers
Old 10-05-2007, 09:26 AM
OK, let me rephrase - do the '87-88 Koni inserts have the same diameter shaft as the stock struts? Or, in other words, do I have a choice of bump stops or do I *have* to use the Konis?
thanks,
nate
Old 10-05-2007, 10:43 AM
flash968's Avatar
same, or at least they work - i had the oem bumpers in there for a while on my konis - lol - i was too lame to remember to order new ones at the same time i ordered my struts - the next time i changed springs i changed bumpers
Old 10-05-2007, 11:09 AM
