-   -   944 Auto . Damper plate mod? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/370190-944-auto-damper-plate-mod.html)
gwass 10-03-2007 08:26 AM
I have a 944 auto and the rubber damper plate is very worn. Cost of replacing it is $1000. To much. Heard of a mod. get flywheel off a manual engine complete with clutch which has a spring damper in it. Off S/H engine. Has anyone done this? will I have to change the torque tube as well?
944 Ecology 10-03-2007 04:37 PM
There is no such mod.
gwass 10-03-2007 09:29 PM
Are you saying that it is not possible?
944 Ecology 10-04-2007 03:04 AM
If you spend enough time and money, you can put a man on the moon.
Anything is possible. Not everything is cost effective.
Why don't you try it yourself and report back???
SmileWavySmileWavySmileWavySmileWavy
tigger2 10-05-2007 02:02 PM
I have question 87 944 with auto, tork tube went bad, took all apart have newer one to put in. Noticed all the tny cracks in the damper, I have looked at several for sale used and they say all have the cracks and that is how they get. How much is to much on one????? Please help! Thanks
gwass 10-06-2007 02:50 AM
Not spent much money or time and done it. Flywheel and clutch off S/H engine. Fits in place of Damper plate and flywheel. No mods to the torque tube. Sweet as a nut and all for 50 dollars. Not enough to put a man on the moon but enough to get my Auto 944 spinning. Next project. Get man on the moon. Maybe one day?
carsontc 10-07-2007 11:26 AM
Don't forget the drive shaft on the automatic has a groove for a circlip and a spacer sleeve in front of the rubber damper that you want to replace. See parts 25 & 26 :
http://www.pelicanparts.com/PartsLookup/HTML/944_2_USA_85_88_KATALOG/307-00-Frame3.htm
This keeps the back of the shaft…with the flex plate and torque converter…from sliding back into the automatic transaxle.
Also this circlip must be removed before the torque tube can come out.
(I think Socal Driver is channeling through me.!)
earlr85944 10-07-2007 02:40 PM
tigger2, post a pic, it will help alot
tigger2 10-07-2007 02:42 PM
damper auto trans
HI COULD YOU EXPLAIN FURTHER HOW YOU DID THIS. BY LOOKING AT A PIC OF THE CLUTCH I SEE THE POSS. THANKS MONTE
tigger2 10-07-2007 02:44 PM
WILL TRY TO GET A PIC OF MY DAMPER MONDAY THANKS
gwass 10-09-2007 06:47 AM
Just replaced the Flywheel and damper plate with manual flywheel and clutch. Remove the clutch thrust bearing otherwise it will rattle. Clutch has a built in cussion drive. My 944 now drives as smooth as silk and all for 100 or $50 . It is not a five minute job as you have to remove the transmission from the Torque tube to allow it to move back far enough to remove the damper and the flywheel. I had to replace the rorque tube as well because some previous heavy handed mechanic had bent the shaft when changing the engine. But well worth the efort and the saving of money made it even better.
944 Ecology 10-09-2007 07:47 AM
I'm impressed that you knocked this out in 5 days from query to completion.
I don's suppose you have any pictures of the process, eh what?
gwass 10-09-2007 08:03 AM
Something aproaching 25 hours on my back. Was well worth the trouble. Never gave it a thought about photos. But clarkes Garage have photos of Transimision, rear suspension removal etc. Plus Pelican Parts Technical diagrams all help in removing the required bolts. Just looked upon it as another of lifes challenges plus I can not afford to pay the going rate to do the job. Quoted 35 per hour. Dare say would have been quicker on a 2 post ramp but sill Mega Bucks. Now my next project is to get my Daughters 49 Chevy Pickup back on the road. More lying on my back sorting some body else Balls Up out. Pardon my spanish.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
