Send a message via ICQ to Stoutpants Send a message via AIM to Stoutpants Send a message via Yahoo to Stoutpants
Low Idle troubles
This past week I have been having some serious trouble with my idle.
1)Sometimes when I try to start my car the engine fires up but immediately dies. This hasn't been a consistent problem.
2)Not long after my car starts it has a very rough time idling. It fluctuates between 800-200 rpm and threatens to die if I don't give it some throttle. My car doesn't seem to have any problems once I give it gas and runs just fine.
Do any of you all have some advice?
Old 10-05-2007, 09:43 AM
Hi, I haven't had your specific problem but maybe check out your idle control valve or your throttle positioning sensor. Also, Look around for any vaccumn leaks or cracked hoses as well.
Old 10-05-2007, 05:15 PM
Banned
procon's Avatar
Send a message via Yahoo to procon
I was having a similar issue with my S, ran like crap till it hit 3000 rpms & then it would smooth out. Turned out to be two shot plug wires & some carbon build up.
Old 10-06-2007, 07:38 AM
I just hooked a multimeter up to my TPS today. Everything read normal. I think my next step is to check the injectors and replace my relay. I know it's not my spark plugs. I had those replaced a month ago.
Old 10-06-2007, 12:30 PM
Politically Incorrect
onZedge's Avatar
How old are the cap/rotor/wires?
Edek
'87 924S
'91 535i
Old 10-06-2007, 07:24 PM
Engine swap pro
myskyon's Avatar
i would say have a look at this post again and see what you com up with. this problem would be most noticed when cold. also +1 on a vacume leak.
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 10-06-2007, 08:00 PM
Banned
procon's Avatar
That's my bet.
Old 10-06-2007, 09:08 PM
Ernest Hill's Avatar
if you do not know how old your rotor/housing are, replace them, not difficult nor expensive; and wires do wear out but are expensive, so, if the problem continues: get a spark/ignition tester, not expensive, check your spark at the wires. my advice: test before you replace, b/c i have spent more money replacing good parts than the diagnostic equipment would have cost in the first place
Trust no one who does not drive a Porsche daily. just kidding. Sort of
Old 10-07-2007, 04:15 PM
Engine swap pro
myskyon's Avatar
cap and rotor will not cause a low idle i can show you pictures of mine that would runn to 130mph no problem and you will gasp at what they looked like. shoot i will just show you anyways. there was no idle problems with the car it showed up as a boost problem. so that is why i would lean heavy on the vacume leak or the idle set screw backed out or the ISV is stuck open. though the cap and rotor are good things to look at and should be i would not put my money on them unless the cap is loose if its not well then i dont know.
Old 10-09-2007, 05:38 AM
onZedge's Avatar
The more detailed info, the better...
stoutpants - we need more info.
You didn't say whether you have a low idle problem once the car was fully warmed up. Did you check your DMEII temperature sensor? Has the outside temperature fallen below the dew point at night recently (ie.: condensation on the plug wires)?
Edek
'87 924S
'91 535i
Old 10-09-2007, 08:24 AM
