Question Where's the oil pressure sender???
I heard that the reason my oil pressure guage is always reading 5 bar is that my oil pressure sender unit is bad so I ordered a new unit. Now I can't find it on my engine. My Haynes manual is no help of course.
Anybody know where to find it??
Thanks,
Dave
Old 10-05-2007, 09:16 AM
Look below the oil filter.
Good luck, George Beuselinck
Old 10-05-2007, 10:02 AM
It makes it a a lot easier to pull the passenger front wheel. It's below the oil filter. I'd wait until you change your oil next, (I'm in the process of doing mine) I've heard that oil will begin weeping out if you remove the old sending unit with oil in.
-1989 S2
-1986 Land Cruiser
Old 10-05-2007, 07:01 PM
Unhappy
Okay I found the sender, replaced it but the guage still reads 5 bars all the time. Did I replace a perfectly good sender unit?
Old 10-05-2007, 08:44 PM
Send a message via Yahoo to Cebu
Check for grounded wire from below MAF down to sender
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 10-06-2007, 09:01 AM
Engine swap pro
myskyon's Avatar
what wheight of oil are you useing? that will make it peg at 5. if its 20w50 you may have just replaced a good sender. 20w50 will show you only peged unless its 140f and you are running the car very hard on say a track then it may drop a little. if you read your manual and use porsche approved oil then its a diffrent story.
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 10-06-2007, 03:39 PM
Politically Incorrect
onZedge's Avatar
The gauge will peg high if it's wired backwards.
Edek
'87 924S
'91 535i
Old 10-06-2007, 08:26 PM
