Wastegate Shims Install Pics
Anyone have pics of a how to on install wastegate shims...Thanks in advance.
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red Last edited by chitown944; 10-13-2007 at 01:21 PM.. |
Umm, how hard could it be?
Hard enough wise guy...
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red |
No pics but it really in't too bad. Now if you were talking about the turbo mounting bolts,one in particular, then I would say otherwise
![]() you just need to remove all kexhust components from the wastegate ie; little trnsfer pipe,and wastegate outlet. They have to come off b/c it won't move rotherwise. then you have 3 blot holding it ot the mounting bracket, one of which also would be a shimed location. then drop it down and remove the hose clamp. when you put it back together make sure you leave the bolt out that is alsoo used for the mounting bracket, Pretty easy really oce you do it once it only takes a few minutes to pull teh next time. I have foound that a torx bit is good for soe of teh stubborn bolts w/o stripping them in place of teh 6mm
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
