Rear Camshaft Gasket Replacement
So I did the search and didn't come up with what I was looking for.
Can you guys offer any tips on how to do it? It's so tight in there, I can't even get to all the bolts and nothing around it seems to move. Are there any special tools that would help make the job much easier? It's one of the last things I need to do to the car to get it back up and running. Thanks guys.
PCA Member 86 951 Blk/Blk Guru Chips, Momo MonteCarlo Wheel, Kinesis 17" SuperCups |
winter-hater club member
is it leaking oil? if so, how bad? have you tried just tightening the bolts?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
lol yeah it is! I can barely get my hands in there at all!
Well I've got some type of oil leak coming from the back end and I can't think of anything else. I read up on posts and saw that this seems to be problematic and it was a cheap part so I would start there. Never knew it would be so much work to replace a $2 part. lol
yeah its bad. the bolts on mine had backed out. a little tightening fixed the leak. you don't want to tighten really hard, as the gasket is cork and will get damaged.
Politically Incorrect
Edek '87 924S '91 535i |
Not Special
It's a pain - easier to take the whole cam tower off. Trust me, when I did it with another PNW-er, we had to take it off and do it that way.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen Former: 1985/1 Porsche 944 - Graphite/Black |
That Guy
Ratcheting flex head gear wrenches! Its still a pain in the ass, but a little easier with these.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Taking off the cam housing to replace the rear gasket???????????????????????????????????????????? ?????????????????????????????????????????????????? ??????????????????????????????
You need a 10mm combo wrench and patience.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Compact cars require compact mirrors!
Yor wife/girlfriend will certainly have an old makeup compact with a mirror you can scavenge. This is one of those times that a small mirror in your toolbox is a must.
Not Special
Yeah, when you need to do both it makes sense, doesn't it?
It does, but then again you have to actually explain what you were doing, which was not replacing only the cam box end gasket.........................
In other words nothing to do with the original posters question.
