Custom User Title
Clutch Question
I have an intermittent problem with my clutch. Sometime when I start it up the clutch doesnt fully disengage despite having the pedal all the way in. The car will start but I believe the clutch slips (otherwise I would be through the wall of my garage) I also sometimes have an issue taking the car out of first and need pull more than normal to get to second. The clutch itself is most likely original with 150,000Km (less than 100k miles) but does not slip at all in any testing I have done. Is there any adjustment that can be made here? shift linkage problem, Clutch adjustment??
meister member
There is an inspection window on the clutch bellhousing where you can measure you clutch plate thickness. clarks-garage may have a write up on this.
I don't know of any adjustment but you could try bleeding the clutch. Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Custom User Title
master and slave cylinder were replaced last year
the fact that they were replaced last year doesn't mean anything...
I'm going through them yearly.. and vinman i believe went through 4 in a year.. they're pretty weak points on these cars.. as for starting it up, why not just start it out of gear?
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Custom User Title
The clutch master and slave were changed last year so the system was bled then. The problem existed before the new parts and still now. I will still check the salve/master to rule that out. As far as starting out of gear, yes thats a good idea but I would still like to solve the problem.
meister member
I am not sure if the 'S' has a rubber centered clutch disk or not but that has been known to cause trouble.
When my rubber center went, I couldn't shift out of gear. Speedy
while we're on the topic, how hard is it to change out the rubber center?
Nobody Special
I'm not sure how many miles are on your car but I've seen so many clutch forks with serious wear on the two bearing contact surfaces. It can reduce the travel enough to be an issue if the disc is also worn thin. You can try pressure bleeding the whole system again if the travel through the inspection window is within spec. I assume that when your clutch was done the pedal free play was adjusted for the new disc? Too much play and it has trouble disengaging; too little or none and it will slip.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD Last edited by 2Tight; 10-22-2007 at 09:45 AM.. |
Ornery Bastard
Same effort as replacing the clutch. I don't know of a way to just swap the center portions of the clutches.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
I just purchased a 968, and was informed this past weekend it has a hydralic clutch. I've never owned a car with one as far as I know before. I have replaced a clutch in my old Mustang GT, and it was a pretty tough job.
I thought my clutch was fine, although my Dad thought it was a bit weak when he test drove the car. I have noticed that when I park the car pointing uphill, and let it get cold (like in my driveway) that after I get in and start it, it doesn't want to pull out of 1st gear easily. Other than that one issue it performs flawlessly. SO, could this mean I need to bleed my clutch? I also cannot engage the ABS, the brakes are not strong enough, even though they have plenty of pad left. I planned to have the brake fluid system flushed to ensure I have good fluid and no air in the lines. Could this be related? |
Nobody Special
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
Well I wouldn't say it's slipping. Just that sometimes it's hard to pull out of first gear after having parked it. And my driveway is not steep at all, it's just a mild slope.
How to bleed clutch? Is there a bleeder valve like on the calipers under the car on the clutch housing somewhere?
Can I purchase a speed bleeder (like I plan to for the calipers) for the clutch? Any recommendations on the best brake fluid to use now in 2007? |
winter-hater club member
yes. ATE racing blue. (pronounced AH-tay, i think)
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
In reference to the 968 owner whos car doesn't like to come out of first when the car is parked on a grade. My 83 944 does the same thing and I believe that it has nothing to do with the clutch just maybe the shift rod gets bound a little somehow and needs a little more persuasion to get it out of first than normal.
also in response to the 969 parked on an incline.. my 83 does that sometimes... letting it roll a couple inches first lets it shift like butter again..
purchased an 88 924s several months ago. A few weeks ago, the clutch pedal stayed half way - I pulled it back with my toes. Noticed the brake light intermittent-filled the reservoir which was low. All seemed ok. Yesterday I found the clutch pedal against the carpet-if I pull it up, there's spring tension only. If I push on the pedal, the spring tension pulls it straight to the floor. Any ideas?
Ornery Bastard
Bleed the clutch system and see if that fixes it. If not, you will need to replace the clutch slave cylinder. I recommend changing the master cylinder as well since they typically both fail around the same time.
Redline Racer
Or you could replace just the seals if the actual cylinders are still in good shape. I've done it to both master and slave for a fraction of the cost of new ones, and it has worked flawlessly for almost a year of daily driving.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Wow, a lot of people having clutch hydraulic issues. I would reccomend getting factory parts directly from Porsche, they really arent that much more, but have a two year warranty and are not reman parts like a lot of the discount parts, I havent had a factory one fail earlier than one would expect.
Mark |
