944s oil
my car came with no manual . what is the correct motor oil for a 87 944s
Old 10-18-2007, 06:25 PM
winter-hater club member
nynor's Avatar
the one you like. that said, 10W40. YMMV.
"COOL PRIUS!" - Nobody Ever
Old 10-18-2007, 06:28 PM
Redline Racer
HondaDustR's Avatar
Or Mobil1 0W40 for cold weather. I like the mobil1 5W40 turbo diesel oil, mostly because it still complies with the old API SL spec instead of the newer SM spec.
It's kind of a long story, but there was a thread a while ago questioning the issue of SL vs SM, since the SM specified a drastic reduction in phosphorous based anti wear additives in the oil to make it more environment friendly. Several people were concerned that the hydraulic lifter design used in older cars, including the 944 lifters, needs those anti wear additives to be properly protected. I have no idea what's really the case, or whether the oil manufacturers have made a substitute non-phosphorous based additive that does the same thing, but I know diesel engines operate on much higher bearing loads and temperatures, and require the higher % of anti wear additives to last a long time (every diesel oil I've seen is SL, and just about every new car oil, except for mobil1 high mileage, is SM). The Mobil1 turbo diesel oil is advertised as being extra resistant to thermal breakdown, has top notch high pressure film strength, diesel grade antiwear additives, and also has the API CI-4 spec only found on heavy duty diesel oils. The standard diesel CF spec can be found on just about any half way decent oil, but the CI-4 is only found on the high grade heavy duty diesel oils.
Being uncertain about this issue, and being able to feel good about the fact that mobil1 turbo diesel oil is probably more than enough for anything a 944 motor could demand from an oil, that is what I use. And being a high quality oil, I let it go for 5000 mi. between changes, and it holds up really well. It could probably go longer, but I'd rather change oil than worry about learning how to replace bearings down the road. I know that several pelican members use the synthetic Rotella diesel oil as well, and is also a very good choice.
Edit: I should also add that the Mobil1 Turbo diesel oil is readily available at any Walmart for less that regular Mobil1 costs at the auto store. I don't have to worry about hunting down/special ordering some fancy performance oil.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 10-18-2007, 08:59 PM
Banned
procon's Avatar
Send a message via Yahoo to procon
I'm running Mobil 1 15W - 50
Old 10-19-2007, 04:09 AM
Tidybuoy's Avatar
Do a search on this board. Quite a while back (within a year) someone posted a very good post on oil and what the viscosity means.
The oil that you uses is not specific for your 87 944s is more related to your climate. This article had some really great tips regarding multi-grade oil and how vastly different multi-grade synthetic is from regular oil.
Vern
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 10-19-2007, 09:50 AM
Burn the fire.
Brando's Avatar
I'd recommend Brad Penn 10W30.
[x] Working | [_] Broken: 2017 Victory Octane
[_] Working | [x] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 10-19-2007, 01:46 PM
nynor's Avatar
ah... another oil debate. well, i was going to try and avoid this, but here is my .02:
10/40 amsoil. i let it go for 9000 miles (they claim 12500) and change the oil filter every 3000 miles with the proper mahle filter.
Old 10-19-2007, 02:44 PM
martin944's Avatar
for my 87 44S i use 20/50 during summer and 10/40 for winter.
Old 10-19-2007, 08:16 PM
Redline Racer
HondaDustR's Avatar
Ooh..a 944S in Germantown (drools...)?! I'll have to keep my eyes peeled. I drive to Damascus 5 times a week.
Old 10-20-2007, 05:36 PM
martin944's Avatar
it's white, say hello if you spot me driving around.
-martin
Old 10-29-2007, 08:49 AM
Super Moderator
nize's Avatar
there really is only one mobile1 that's porsche-approved: 0w40
read this thread;
Oil viscosity question- rebuilt engine
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 10-29-2007, 10:15 AM
sasquatch's Avatar
Shell Rotella T Synthetic 5/40 diesel oil. Been running it for over 100k miles.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 10-29-2007, 11:11 AM
callmethewander's Avatar
I only use cold pressed extra virgin olive oil, italian if i can find it but greek isn't bad either
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 10-29-2007, 02:30 PM
Super Moderator
nize's Avatar
you could probably run the car just fine on 100% vegetable oil for 100k miles, or even billy joe-bob's super sekret wonder oil. it doesn't prove it's any good, though.
Old 10-29-2007, 02:32 PM
sasquatch's Avatar
Well, the car has 190k on it, uses no oil, leaks no oil, runs like a top, and has great compression. I think the Rotella is great!
Just because Mobil 1 is a great oil, does not mean it is the only great oil.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 10-29-2007, 03:09 PM
Engine swap pro
myskyon's Avatar
porsche approved that is the only kind of oil you should run in your car. All oils that are porsche approved will say so on the back in small print.
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 10-29-2007, 03:25 PM
i've tried the porsche approved but found that after draining it from the car it gives my red leaf lettuce a bitter taste
1989 S2
1988 S
1987 944 n/a (sold)
Old 10-29-2007, 03:39 PM
sasquatch's Avatar
I got some mountain land in Florida for sale. Interested? Like I said before, 100 of the 190k on the car has been on Rotella. Tell me how it is not a fantastic oil?
"Porsche Approved" means that Mobil 1 was the one of the many oils that met Porsche's specs, but edged out the competition by giving more kickbacks/advertising/race sponsorship to Porsche, not that it was the best.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 10-29-2007, 03:47 PM
sasquatch's Avatar
My wife found out that if she added a hint of garlic to the EVOO, the smell had me very hungry by the time I got home.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 10-29-2007, 03:49 PM
Haha, Now We're Talkin Oil!
1989 S2
1988 S
1987 944 n/a (sold)
Old 10-29-2007, 03:54 PM
