944 air filter
hi im wondering if its possible to fit a cone air filter into an 85.5 944NA. i currently have the stock box air filter. i know is been done on turbos and s type havent seen much done on the NA. is there something different to be done to transform or do i just remove my old box and install the new one. also any suggestions to brands and where i can buy a good one would help. if u want u can email me at ay9541@wayne.edu
thank you |
winter-hater club member
do a search. there is a lot of controversy/opinions about the cone filters.
my .02: leave it stock. its easy. its cheap. it works well. there is a cold air snorkel built into the system.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
I'm with Bill
You can use a cone filter on the car but you will be sucking hot air from above the rad. just buy a K&N to fit the factory airbox and drive on.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
thank you for your replies. i take it thats its not worth it.
meister member
instead of a cold air intake you would have a hot air intake which you would decrease the air density and lessen HP. Stock box with a stock filter is best.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Redline Racer
Detach the snorkel from the airbox and you'll get a really nice intake sound, especially with a K&N filter. The intake stub is still kind of out of the way of the radiator and angles down toward the wheel well. It doesn't do that well in traffic on a hot day, but what difference does performance make in traffic anyway? Besides, you can just snap it back on if you don't like it. It's better than drilling the top like some do. It really does sound awesome!! esp at WOT @3500 rpms.
![]() Btw, not that it matters, but the narrowest point in the end of the snorkel is actually a little smaller than the Throttle body bore. I know the AFM is the biggest restrictor, ect ect, but it makes me feel good!
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 10-21-2007 at 06:30 PM.. |
