-   -   How do you reinstall the 1st position fan relay for a 844 944? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/373164-how-do-you-reinstall-1st-position-fan-relay-844-944-a.html)
drball01 10-20-2007 02:23 PM
I removed the relay to test it while troubleshooting my fan problem. It was a bear to remove but there is no way I can figure out how to reinstall it. Is there a trick or am I just missing something?
onZedge 10-20-2007 02:36 PM
Just push it in.;)
onZedge 10-20-2007 02:43 PM
OK, really...
Make sure you have the pins oriented correctly. Use electrical contact cleaner/lubricant like CRC QD. That relay is on the top row of the relay/fusebox. The top row of relay sockets are snapped in to the relay/fusebox "motherboard" and can flex quite a bit.
