1982911sc's Avatar
Royal Purple Gear Lube
Last weekend I replaced my transmission fluid with Royal Purple 75-90 full synthetic. I only have about 100 miles or so on the clock with the new fluid, but I have to say to say shifting has greatly improved. Cold shift is slightly better than the old fluid, which I am not sure what it was (gold color). However, once warmed up shifting is very fluid and smooth, like butter!. Has anyone else tried the the RP? I was debating this versus Swepco.
1986 944 Turbo.
944 TURBO!!!!
1982 911 SC Targa (loved but sold!)
2005 Cobalt SS (0-60 in 6.1!!)
2003 BMW 325i ex got in divorce
1969 912 Coupe (sold)
PCA Member
Old 10-30-2007, 07:51 PM
I've been racing on it. It's louder, but I've liked it the last 2 years.
My race buddy said it's all die. Can't compare smoothness but my tranny is still working after much abuse.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 10-30-2007, 10:59 PM
Quality
phoenix_iii's Avatar
Porsche Crest
Oh good. I was going to have to search but here is the thread!
How much does the 944 (85.5 NA) trans take? (5spd)
Going to buy some from the local speed shop this week. Anyone have the link to a walkthrough? Getting my Haynes manual shortly, but may be better methods from you guys to follow... =)
Old 10-31-2007, 05:53 AM
Politically Incorrect
onZedge's Avatar
5-Speed transaxle takes 2 litres. With the car on a level surface pump it in until it starts to run out of the fill hole. Always remove the fill plug BEFORE the drain plug.
Edek
'87 924S
'91 535i
Old 10-31-2007, 09:59 AM
Quality
Will just draining it cold get all of the 2 liters out? Can it be 'over-filled'? Doesn't sound like it. What size sockets for the drain and fill? (Haynes manual arrives soon but I am sure some one would like to know).
Old 10-31-2007, 11:25 AM
1982911sc's Avatar
I think it is a 17mm Hex, but don't hold me to it! And no, you can't overfill it, when it comes pouring out your done!
Hey Jim, what does your race buddy mean by all die. Like dye in color?? It is a very neat purple color, but man does it shift nicely!
944 TURBO!!!!
PCA Member
Old 10-31-2007, 01:01 PM
onZedge's Avatar
Easier than an oil change...
Originally Posted by phoenix_iii View Post
...Will just draining it cold get all of the 2 liters out?...
No, but you could try jacking up the passenger side of the car to help get as much out as possible.
...Can it be 'over-filled'? Doesn't sound like it...
You are correct. With the car on a level surface, you pump it in until it starts to come out of the fill hole. No chance of overfilling unless you deliberately try to do so.
...What size sockets for the drain and fill?...
Both are 17mm Allen sockets. I would recommend a 1/2" drive bit socket and breaker bar to get them out as they are usually very hard to get out. Make sure the sockets of the plugs are clean or you might strip them out. AZ carries the big metric bit sockets. About $10 for a set of three sizes including 17mm.
Edek
'87 924S
'91 535i
Old 10-31-2007, 01:06 PM
Quality
Porsche Crest
onZedge, thank you. Already have 17, and some other goofy sizes, in 6pt, from other car escapades. =)
Will hit it with PB Blaster and then see if I can get impact on it instead of breaker bar, just seems to work 'right' for removal. Installation I will use a torque wrench of course. =)
Thank you!
p3
Old 10-31-2007, 01:14 PM
onZedge's Avatar
I wouldn't use an impact on it!! The housing is aluminum and you risk cracking it!! PB Blaster and a breaker bar is a better plan...
Edek
'87 924S
'91 535i
Old 10-31-2007, 01:22 PM
1982911sc's Avatar
I have never encountered a bolt that will take on my 1/2" breaker bar!
944 TURBO!!!!
PCA Member
Old 10-31-2007, 03:07 PM
Quality
Thumbs up
10-4. It's just usually I do not get the cars very high (lousy jack range, but good jack stands), so some times leverage isn't best... I will use my pb + breaker bar.
Didn't think about a susceptible housing...
Old 10-31-2007, 03:55 PM
One apex at a time
Dean924s's Avatar
Can Anyone compair it to Mobil one Gear oil?
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 10-31-2007, 06:15 PM
1982911sc,
Buddy says the purple is just a selling scheme. I'm like, no kidding... You mean it doesn't come from specially formulated noble class, Squids. But he is also a purist who puts in everything by the manual, published in 1987. I've had some good gear heads say stay away from Mobil 1, but I used that alot before in motor oil. Now it's Royal Purple XLR 20/50, Redline, or Liquid Molly Motor Oil; and Royal Purple Tranny Fluid. Mobile 1 was great on the street for normal driving but to thin for high track temps IMO.
Old 10-31-2007, 11:33 PM
mr. dude's Avatar
I've used Mobil 1 in my N/A's Tranny with good results.
2006 Porsche Cayman S
2006 Lotus Exige (Sold)
1986 Porsche 944 (Sold)
1981 Porsche 931 (Wrecked)
1987 Porsche 944 (Sold)
Old 11-01-2007, 04:39 AM
Quality
Thumbs up
Originally Posted by JivenJim View Post
1982911sc,
...You mean it doesn't come from specially formulated noble class, Squids.
l0lz
It made a noticable difference in my 87 MR2 5spd with 99k on the clock, and the fluid I pulled out was 'new' regular stuff, still looked good. =)
Old 11-01-2007, 07:28 AM
Misunderstood User
Just had my 83 n/a tranny with lsd rebuilt. Rebuilder recommended Mobil 1 75w90. Bought 2 liters of Mobil 1. So far so good.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 11-01-2007, 11:49 AM
One apex at a time
Dean924s's Avatar
I have always used there gear oil and had very good results.
It seems to be the base line that others are measured by. I am sure some are better but for what I do it has served me very well. I was just curious if anyone had dome any type of comparison between Mobile 1 and Royal Purple
Respectfully
Dean
Old 11-01-2007, 04:42 PM
Aslet's Avatar
I looked on Clarks and didn't see any info, so I will ask. How do you change the tranny fluid? My car shifts nicely and it probably was done according to the maintenance schedule, but it might be another to-do item, part of my long term maintenance...
-Randy
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 11-01-2007, 08:39 PM
onZedge's Avatar
Look harder:
http://www.clarks-garage.com/shop-manual/trans-06.htm
Edek
'87 924S
'91 535i
Old 11-01-2007, 11:20 PM
Aslet's Avatar
Woops, helps if you can read i guess Thanks though
-Randy
Old 11-02-2007, 05:23 AM
