Another?
How does the cam belt going over the WP appear on your car? Is it steady or does it vibrate? The portion after the WP to the cam gear is the area I question.
Dal |
Pretty steady on mine. Make sure that the drive gear on the crankshaft has the lip towards the front of the car. If not, the timing belt can slide forward and this can cause it to misalign on the cam gear. Also make sure you have tightened the nuts on the spring tensioner (All 3 mounts and both tensioner release nuts.)
John 1987 924S PCA Class I |
I must have had some slack as it is ok now. How I do not know but seems fine now. Thanks John
Dal |
| All times are GMT -8. The time now is 07:30 AM. |
