Oil leaking
My 1987 944 NA leaking oil.I hear allot about how leaking oil for a Porsche is normal. I seen company like KLA who claim to make a special bracket to will help the oil pan gasket from expanding and fix the oil leaking problems. I just read an posting on Pelican about the rear cam gasket causing some leaking issues as well. Does any body have advice?
yes, get under the car w a few rags and wipe it as clean as possible, remove the plastic farings first if they're still there. go for a nice ride, then drive it up onto ramps and look for where the oil's coming from. be careful not to go directly underneath the leak so you don't get burned by a drop. if it's your pan, count your blessings
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
Politically Incorrect
If it's the rear cam tower cover gasket that's leaking, try this link:
4th hole myth BUSTED (with pictures!)
Edek '87 924S '91 535i |
