Putting Cam Tower back onto head, Wont seat
Im trying to put the cam tower back onto the head, i have the tower in positions but it wont go all the way down. Can somebody tell me how to get this thing on, thanks josh
1987 944 n/a
Old 11-04-2007, 02:38 PM
meister member
speedracing944's Avatar
There are 2 dowels, one on the front and one on the back. Make sure these are going in the holes in the cam tower.
The cam tower will sit above the head about 3/4" due to the valve springs no being compressed. Once you insert the bolts and start tightening them the springs will compress.
Is your flywheel locked at TDC?
Is you cam at TDC?
Make sure to tighten the cam tower bolts evenly and a little at a time so the tower does not bind. Also make sure the valves are actualy inside the cup on the lifters.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 11-04-2007, 03:23 PM
thanks, yes the motor is at TDC and so is the cam, thanks for your help, you guys know your stuff. thanks josh
1987 944 n/a
Old 11-04-2007, 04:09 PM
That Guy
Techno Duck's Avatar
Good advice. Tighten in x-pattern starting from the center most bolts.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-04-2007, 04:11 PM
