plugging waterpump heater port
Im having a really hard time finding a plug for the waterpump to do my heater delete. I see them in auto stores but never big enough for this port. If somebody can find me an online source it would be great.
Old 11-01-2007, 04:49 PM
Just thinking out loud
mattdavis11's Avatar
Never heard of one. Your local hardware store might have something to plug it. You might even check to see if a drain plug for a boat would work. Not the top one.
91 FJ80
84 Ram Charger (now gone)
Old 11-01-2007, 06:08 PM
I was hoping to find something like this
Old 11-01-2007, 06:18 PM
I've used Rubber chair peg covers available in any hardware store. They're cheap. Will be sloped but works with a well placed hose clamp. Even used Rubber corks from Wine bottles on hose with clamp sections. Does that make me a red neck? Keep an extra in your race spares, but should be good for the season.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 11-01-2007, 06:51 PM
earlr85944's Avatar
you can also use a section of heater hose (to withstand water temp) and a plug (bolt or round stock) with a hose clamp in the end
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 11-02-2007, 04:08 AM
Politically Incorrect
onZedge's Avatar
Lighter is faster.
The section of plugged heater hose is a good idea, but I think a sweat-on copper pipe cap used to plug the other end of the hose would be better than a bolt or bar stock. Lighter, easy to find in any plumbing department and cheap.
Edek
'87 924S
'91 535i
Old 11-02-2007, 09:14 AM
Thats exactly what i ended up doing, id still like to find a plug for it though so it looks neater and will be less prone to leaks
Old 11-02-2007, 01:51 PM
