Part numbers?
I am looking for the part numbers for the foam seals that seal the vents to the dash. I have removed my dash to get it re-coved (sic of the cracks) and found that all the foam seal are toast. I can not find a listing for these seals so has anyone replaced these and if so do you remember the p\n. The one I am looking for is located in the center under the stud that holds the dash on its for the demister vents.:confused:
Thanx in advance:D Baza |
Hey Baza,
Not sure if/where you can find the OEM seals for the fresh air blower vents. Only suggestions I can offer is either use some 3M foam with the adhesive backing (available at most home improvement or auto stores) Or you check ebay for some vents that have good foam on them. Here is one auction that he's selling 83 trim pieces including the fresh air vents. Item Not sure on the color of your dash but it's worth a shot. BTW when you have it all back together I would like to see a picture. Good Luck |
Thanx ROB
I totally forgot about 3M products to caught up in the get the right part for the job thing. Here is what the dash looks like now http://forums.pelicanparts.com/uploa...1194163543.jpg I'll post when finished I have some ideas I want to try out so it could take a while looking at FEB 08 for completion. |
| All times are GMT -8. The time now is 11:41 AM. |
