KY944S's Avatar
924 manual rack in 86n/a?
Just wanting to know if a 924 manual steering rack will work in a 1986 944n/a?
Would it matter if it was an early 924 or late?
1987, 944S (168,000 miles)..sold
1986, 944na.
My job is a hobby. My 944's are work.
Old 11-12-2007, 08:25 AM
TNT25169's Avatar
Send a message via AIM to TNT25169
It will work but you need the manual steering shaft that connects the the steering rack to the steering wheel. The manual is about 7/8ths of an inch longer than the power steering one and they are kind of hard to find. You will also need the manual tie rods meant for a 23.3mm offset.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 11-12-2007, 08:48 AM
That Guy
Techno Duck's Avatar
The 924 manual rack will not fit..different part.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-12-2007, 09:53 AM
KY944S's Avatar
Just found all that out. Thanks
1986, 944na.
Old 11-12-2007, 11:03 AM
