-   -   Throttle response mod (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/376648-throttle-response-mod.html)
markt944 11-10-2007 08:45 AM
Anybody fitted it?whats the difference ? and will it fit a 16v S2?
Thanks Mark
thoen 11-10-2007 10:25 AM
if you are talking about the response cam, yes. it is a great improvement and should fit all 944s.
markt944 11-10-2007 10:30 AM
Yeh thats the one ,but after haveing a look round the net its only for 8v cars
is this true?
mark
thoen 11-10-2007 10:42 AM
if the 16v cam is different, then i guess they don't fit. look at a 8v throttle cam and see if it is like yours. i can't see a reason for them being different in NA cars.
running_cold924 11-10-2007 10:58 AM
they are only for the 8v cars because the s and s2 use a pulley for the linkage, then routed directly to a throttle body, nothing like a pulley on an 8v
but they do work on 924S's because they have the 8v 944 engine
i know on my 944s it won't work, checked into it already.......my throttle cable comes from the firewall and wraps around a pulley to direct it back to the firewall to the throttle body. the goofy intake on those cars is annoying, everything is backwards....
hope this helps clear some confusion
markt944 11-11-2007 08:56 AM
Ok thanks had a quick look and its no go ,they are for they 8v cars only
mark
phoenix_iii 11-13-2007 03:26 PM
Can you link to it? Who sells it? Easy to install? What kind of improvement are we talking (how would you measure that?)? =)
SmileWavy
Techno Duck 11-13-2007 04:57 PM
http://www.rennbay.com/throttle-cam-c-53.html
No gains at all. It just makes the throttle more sensitive.
HondaDustR 11-13-2007 10:34 PM
No, really!! It actually adds 10 hp. ;)
I think you can just cut the stock one for the same effect. It'll just cut out the mushy off idle response. I find it easier to drive once you get used to it.
mr. dude 11-14-2007 06:54 AM
This explains it pretty well....
http://www.dietersmotorsports.com/tech/2001/944_throttle_cam.htm
jcommin 11-14-2007 09:40 AM
I have modified my throttle cam as outlined in the attached article. The new hole location is right on. The trick to this is how much metal to remove to have this dual position. It takes some trial and error. Need a dremmel tool with a cut off wheel to remove the metal.
Other option to cut off the extended part of the cam and relocate the hole.
There is no HP gain, only better response from the throttle.
gtroth 11-15-2007 09:49 AM
The S throttle cam is already round from the factory. I bet the S2 is the same.
Marcone 11-19-2007 10:29 AM
The S2 is not the same as either engine... the S2 is a direct wire from the throttle to the airflow housing.
