rims for a 86 944 n/a
wanted to know if it is possible to put aftermarket rims on a 86 944 n/a. I have stopped by 4 or 5 dealers in the area and none of them are able get rims for the car. is it possible to get done
That Guy
Sure is. You need a 5x130 bolt pattern and in the area of a 23.3mm offset. You can all of the newer style Porsche wheels with the correct spacers also. Many options available. Depends on what you had in mind.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Non Compos Mentis
Porsche is the only manufacturer to use the 5x130 bolt pattern, so you will have to use Porsche-specific wheels.
There are lots of choices out there. |
