-   -   Contemplating the project.... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/376768-contemplating-project.html)
andrew_924 11-10-2007 09:29 PM
My car needs a whole variety of work (its a long list) and before I dive into I thought I would consider upgrading my '80 924 to Carrera or Carrera GT spec. However, I've haven't been able to find an outline of what parts are required to undertake this. I'm not even sure if the stock motor needs to be replaced....
Has anyone tried this before? Does anyone know of a manual for this? Parts Diagrams?
Any info would be appreciated.
JivenJim 11-10-2007 09:55 PM
I think GT Racing has the Fiberglass. http://www.gt-racing.com/
I thought it was a total Different drive train but not sure.
andrew_924 11-11-2007 04:34 PM
thanks for the link - this solves one of the many questions I had.
and now hopefully someone will post on the mechanical stuff. This could be a fun project....
drew1 11-13-2007 03:45 AM
Carrera GT has the 924 turbo heads. It may have different pistons from the standard turbo & maybe a different cam. It has an intercooler that the 924 turbo does not have. The clutch is different from the standard turbo & the wastegate spring is, too. The ignition distributor curve fuel distributor & warm up regulator may be different.
The GTS has other differences I know of. An aluminum roll bar, 935 type brakes & struts (ball joints NLA), a regulator type boost ajustment, and an 8 cylinder fuel distributor (replacement NLA but can retro fit 928 or Mercedes). Unnecesary CIS plumbing is gone, decel valve, etc.
