adrian jaye's Avatar
volts/oil gauge readings
ok fellas
Took the 44 out of the garage (after a years of no use) whilst in the garage, was on battery trickle charge.
After loosening up and an oil change all seems ok
For past few coup[le of drives the oil gauge was hitting 5, now (last drive in to work long motorway drive) she now only hits 5 on throttle, on idle she goes down to 2/3
The volts gauge, whilst not in the red (16) stays on the 15 mark
should I be concerned ?
thanks
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 11-19-2007, 02:31 AM
That Guy
Techno Duck's Avatar
The oil pressure will peg at 5+ when you first start the car. As the car warms up, the oil pressure should drop to anywhere between 2 and 4 bar. Under throttle the pressure should go back up to 5 bar. It really depends on the weight of the oil your using and the temperature outside. From experience, figure 40 degrees F outside and using 10w40..once fully warmed up my car will idle around 3 bar. 20w50 in roughly the same weather will not go much lower than 4 bar at idle.
Not 100% sure about the voltmeter..typically mine stays right around 14v. I dont think its anything to be concerned about though.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-19-2007, 04:32 AM
hey duck,
thankxs, yep that sounds right, used Shell Helix+ 10/40
ok, be nice to know about the V-meter now
cheers
NotJustPorsche
Old 11-19-2007, 04:51 AM
bearone2's Avatar
check the voltage with a decent dvm.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-19-2007, 08:15 AM
