piepoli
Power Steering in '83 944?
Thinking of adding power steering to my '83 over winter. I assume that's a simple parts swap/add? Anything that would prevent it? Thanks guys...
you may need to add a spacer/washer behind the p/s drive pully on the crankshaft...the post '83 crankshafts were longer because of the added p/s pully.
Tom Early '85 944 |
piepoli
Thanks, but as luck would have it I have an '85 engine in my '83, so at least that hurdle is out of the way. Now to start collecting all the misc. pieces. It'll sure make it easier for my wife to park it.
winter-hater club member
i loved the manual steering on my '83. my wife, however, refused to drive it because it was so hard to park.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
If you have trouble locating parts, email me, I might be able to find some for you.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
