-   -   So toasted block right? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/378506-so-toasted-block-right.html)
Smoker324 11-20-2007 06:22 PM
See attached photos taken right after head was lifted off... What are the green blobs? Coolant? Caption Obvious would say that it needed a hg!
http://forums.pelicanparts.com/uploa...1195611015.jpg
http://forums.pelicanparts.com/uploa...1195611117.jpg
http://forums.pelicanparts.com/uploa...1195611170.jpg
What about the splothy areas -- corrosion? What ? I thought Al didn't corrode?
http://forums.pelicanparts.com/uploa...1195611263.jpg
And -- the scratches DO catch a fingernail. What are the chances this will hold compression? What to do?
http://forums.pelicanparts.com/uploa...1195611434.jpg
http://forums.pelicanparts.com/uploa...1195611459.jpg
http://forums.pelicanparts.com/uploa...1195611488.jpg
http://forums.pelicanparts.com/uploa...1195611535.jpg
ANy input would be appreciated. I know that it prolly means I should get a new block.. but I am leery that any e-bay block with have the same probs...anyone have a block out there for sale?
-Thanks
Dan C.
Razorback1980 11-20-2007 06:47 PM
Obviously the best answer is rebuild time. It's been my experience that boring and buying oversized pistons isn't a good option with these motors as the pistons are so expensive unless you can find someone that has some cheap. Buying a new block is usually the less expensive option. I'll see if I can find a couple options for you close by. The part that would concern me is the scratch in the cylinder wall...all the rest probably wouldn't matter too much although sometimes antifreeze does bad things to bearings and piston rings. If it hasn't set any length of time with antifreeze on the bearings, you are probably ok with the antifreeze part. The scratch will cause a loss in compression but without knowing how deep it is, it's hard to say how much. With one cylinder having lower compression, the engine will not idle smooth. If you decide to put it back together, make sure you clean everything including the crankcase very well. Good Luck.
Razorback1980 11-20-2007 06:54 PM
Does yours have the auto cam belt tensioner?
Razorback1980 11-20-2007 07:10 PM
Nevermind the last question...if you are buying just a block, make sure your tensioner is the same in both engines unless they give you the parts for the timing belt area. If you buy a complete engine, it doesn't matter unless you like the auto tensioner which has pros and cons. Other than that, I think the blocks are the same. Zims has new short blocks for 2500 I think. Also here is a couple recycling places you can try:
Auto cam belt tensioner block:
1988
Engine Block
Porsche 924 6A020 $600 Blue Grass Auto Parts USA-KY(Lexington) 1-800-432-0730
1988
Engine Block
Porsche 924 GOOD WILL SHIP,P1030 P1030 $400 European Used Parts Locator (EUPL) USA-ME(New-Gloucester) 1-207-657-2747 / 1-800-374-1239
1987
Engine Block
Porsche 924 7579 $Call DC Automotive USA-NC(Rocky-Mount) 1-800-579-2410
1987
Engine Block 4449 $Call DC Automotive USA-NC(Rocky-Mount) 1-800-579-2410
Probably no auto cam belt tensioner although some 86's do:
1984
Engine Block
Porsche 944 A 720785 $600 European Only USA-UT(Orem) 1-801-224-0859; 1-800-443-6886
1986
Engine Block
Porsche 944 2.5,CRANK,RODS,PISTO N,BLK.BUSTED 1789 $500 Devore Cooke's Auto Parts Co. Inc. USA-NC(Fayetteville) 1-800-682-4313
1983
Engine Block
Porsche 944 BLOCK NOF $500 Best Foreign Auto Salvage USA-PA(Aliquippa) 1-800-370-6002
1984
Engine Block
Porsche 944 - ? POSSIBLE GOOD-U A 007 $350 Auto Parts Unlimited USA-TN(Manchester) 1-800-548-4727
1984
Engine Block
Porsche 944 2.5L,BROKEN-CORNER,C OMPLETE 4856YM $Call Cookstown Auto Center Ltd. Can-ON(Cookstown) 1-705-458-4366
1983
Engine Block
Porsche 944 - A 14199 $Call Abcat Auto Salvage USA-MI(Ypsilanti) 1-800-869-6933
1985
Engine Block
Porsche 944 3332 $Call Standard Auto Recycling USA-CA(Chula-Vista) 1-619-426-1166
1984
Engine Block
Porsche 944 A NOFPOR $Call European Only USA-UT(Orem) 1-801-224-0859; 1-800-443-6886
1983
Engine Block
Porsche 944 - 5776 $Call PorFor Auto USA-CA(Los-Angeles) 1-323-589-2162
1985
Engine Block
Porsche 944 2.5L 11056 $Call Owens Auto Salvage USA-GA(Woodbury) 1-706-553-5757 / 1-866-553-5757
Razorback1980 11-20-2007 07:12 PM
Here are places with complete engines...you may want to pick up a complete engine and swap it:
Complete engines:
1987
Engine
Porsche 944 RWD,MT 267-00 $1900 Kneer's Auto Recycling USA-NY(Troy) 1-518-279-9581
1987
Engine
Porsche 944 WP0AB0947HN475289 3,000 A NOF07 $1800 Don's Sportcars, Inc. RP+ Member USA-WI(Hortonville) 1-800-543-3667
1987
Engine
Porsche 944 1YR WARRANTY FREE SHIPPING UPART $1600 APR USA-CO(Colorado-Springs) 1-888-603-7103
1987
Engine
Porsche 944 2.5,5SP,WONT START 71,000 A R489 $1440.84 M and M Auto Parts, Inc. - PRP, PRP-MA USA-VA(Stafford) 1-800-586-5492 1-540-659-2023
1987
Engine
Porsche 944 RWD,FI,2.5,5SPD GH1906 $1200 Campbell Nelson Auto Recycling USA-WA(Arlington) 888-337-7757
1986
Engine
Porsche 944 2.5,AOD,FLR 002613 $1150 Devore Cooke's Auto Parts Co. Inc. USA-NC(Fayetteville) 1-800-682-4313
1987
Engine
Porsche 944 -CORE CRANK SOLD 122,000 A 030454 $1000 Auto Parts Unlimited USA-TN(Manchester) 1-800-548-4727
1987
Engine
Porsche 944 944- 119K-119K 119,000 A 060712 $1000 Auto Parts Unlimited USA-TN(Manchester) 1-800-548-4727
1987
Engine
Porsche 924 S 2.5 5D2526 $1000 Dixie Too Auto Parts USA-SC(Spartanburg) 1-800-922-2231
1987
Engine
Porsche 944 RWD,EFI,2.5,5SPD,BAS E,OK 202346 $1000 Double T Automotive, Inc. USA-VA(Woodbridge) 1-888-592-8233
1987
Engine
Porsche 944 944-GOOD,117K 605E25 $1000 Forty Three Auto USA-MO(Joplin) 1-888-704-7904
1986
Engine
Porsche 944 GOOD COMP 165 ALL NOF $1000 D & D Dismantlers, Inc. USA-NV(Sparks) 1-775-359-1851
1987
Engine
Porsche 924 47k,needs running 56 $1000 German Parts Source USA-GA(Valdosta) 1-229-242-2048 / 1-800-552-7271
1985
Engine
Porsche 944 LAT NOT S,958854029 958854029 $975 A Plus Auto Salvage USA-TX(Ft.-Worth) 800-877-3220 817-561-2222
1985
Engine
Porsche 944 BURNT 001055 $950 Lalo's Auto Parts USA-TX(San-Antonio) 1-866-551-6622
1986
Engine
Porsche 944 90,000 LPT102 $850 Cherry Auto Parts USA-OH(Toledo) 1-800-537-8677
1987
Engine
Porsche 924 5SP,EFI,RWD 196,484 A 700026 $850 Robertson Auto Salvage USA-MA(Wareham) 1-800-551-7000
1985
Engine
Porsche 944 2.0,FI,ST,170-175PSI H70056 $850 Dorris Auto Wreckers, Inc. USA-CA(Hayward) 1-510-782-4393/1-510-782-4394
1985
Engine
Porsche 944 MT, frm 1/85 (eng #43F 40001)- 159,000 A 06J-05 $850 Trails End Auto and Truck Salvage, Inc. USA-IA(Des-Moines) 1-800-717-6505
1985
Engine
Porsche 944 AT, frm 1/85 (eng #43F 50001)- CC562 $850 All Foreign Auto Parts USA-NV(Henderson) 1-800-797-4607
1985
Engine
Porsche 944 3 85,RWD,MFI,V5FE04,AT AA3520 $850 Cosmello Auto Sales & Parts USA-PA(New-Milford) 1-800-547-6720
1987
Engine
Porsche 944 CORE 110,000 A 063459 $850 Don's Sportcars, Inc. RP+ Member USA-WI(Hortonville) 1-800-543-3667
1987
Engine
Porsche 924 ENGINE 7090 $850 Elite Foreign Auto USA-CA(Sun-Valley) 1-818-768-1350
1986
Engine
Porsche 944 ENGINE SO 7436 $850 Elite Foreign Auto USA-CA(Sun-Valley) 1-818-768-1350
1987
Engine
Porsche 924 2.5,5 Sp,SUPER CLEAN 102,318 A AJ1387 $850 All Japanese USA-NV(Las-Vegas) 1-702-644-2027
1986
Engine
Porsche 944 6 CYL,SD JL0244 $850 Bass Used Parts USA-NC(Fairmont) 1-910-628-5888 / 1-866-917-5888
1986
Engine
Porsche 944 266K,#090348 #090348 $850 Fritz's Auto Salvage USA-ID(Salmon) 1-866-808-3672
1987
Engine
Porsche 944 944-RED (no WIRE HARNESS) P1464 $800.06 Brims Imports Auto USA-OH(Kenton) 1-800-221-3874
1986
Engine
Porsche 944 2.5L,FI,5SPD,RAN OK 12-4-06 190,254 A 6E0169 $800 Helman Auto Parts USA-OH(Sidney) 1-800-231-8733
1987
Engine
Porsche 924 2.5,G,OILED,WELL MAINT,Q29753 108,157 A HH0037 $800 Kubis Auto Parts, Inc. USA-NY(Auburn) 1-800-233-3799
1986
Engine
Porsche 944 105,000 00015348 $770 All Import Auto Parts USA-TX(Ft.-Worth) 1-817-831-6316 / 1-888-629-7194
1987
Engine
Porsche 944 Broken ear needs welded per TF 130,000 00007952 $770 Modern Auto Parts, Inc. USA-MO(St.-Louis) 1-888-919-8138
1987
Engine
Porsche 944 944- G00160 $750 Intercity Auto - ARAPro USA-OH(Bedford) 1-800-438-8733 (Toll Free) 1-440-786-0000 (Local)
1985
Engine
Porsche 944 2.5,5SP,FLR,944,NEED S WELDEDLOTC 95J295 $750 Fagan Auto Parts USA-AL(Piedmont) 1-800-331-5282
1986
Engine
Porsche 944 7-86,NONTBO,AC,AT,CL EAN,-DIST 03-360 $750 Tony's Auto Salvage USA-SC(Spartanburg) 1-800-964-8669
1986
Engine
Porsche 944 3DR,2.5,MAN,FLR 079831 $750 Richards Auto Salvage USA-GA(Austell) 1-800-826-2414
1986
Engine
Porsche 944 2.5L,5SP,1-95,MFI,RW D,FLR ,4-7 118,000 A 05L126 $750 Japanese & European Auto Parts USA-FL(Tampa) 1-813-663-9741
1986
Engine
Porsche 944 151CID,5SP,10-85,MFI ,RWD,FLR,CHK 106,000 A 07F122 $750 Japanese & European Auto Parts USA-FL(Tampa) 1-813-663-9741
1986
Engine
Porsche 944 944- GODD COMP COMPLT MTR $750 Mazda Porsche Parts USA-CA(Rancho-Cordova) 1-916-638-1323
1985
Engine
Porsche 944 MT, frm 1/85 (eng #43F 40001)- TESTED 55021 $700 Mazda Porsche Parts USA-CA(Rancho-Cordova) 1-916-638-1323
1987
Engine
Porsche 944 RWD,FI,4CYL,5SPD J7-458 $700 S and D Auto Salvage USA-NC(Grover) 1-704-482-7222 / 1-888-381-7222
1986
Engine
Porsche 944 CALL 916 368 1323 11-6-07 SM 110,000 A SAM $700 B & M & W Auto Recycling, Inc. USA-CA(Rancho-Cordova) 1-866-631-4269 / 1-916-631-4269
1987
Engine
Porsche 944 -2.5L,5SP,EFI,RWD-K 070732 $675 Tri County Auto Dismantlers USA-CA(Santa-Paula) 1-877-667-2787
1985
Engine
Porsche 944 M.T., thru 12/84 (eng. #43F 20000)- 875,000 C F3117 $650.12 M & M Imports - Will Call Only USA-CA(Fontana) 1-909-428-1111
1985
Engine
Porsche 944 M.T., thru 12/84 (eng. #43F 20000)- F3126 $650.12 M & M Imports - Will Call Only USA-CA(Fontana) 1-909-428-1111
1986
Engine
Porsche 944 PLAN B PLAN B $650.07 Auto Sport Unlimited USA-MI(Zeeland) 1-800-695-1021
1987
Engine
Porsche 944 PLAN B $650.07 Auto Sport Unlimited USA-MI(Zeeland) 1-800-695-1021
1987
Engine
Porsche 944 2-87,3SPEED 121,196 A F0341 $650 Veldman's Auto Parts USA-IN(South-Bend) 1-800-888-3821
1987
Engine
Porsche 944 944-148k 148,000 A B01007 $600.27 Nationwide Auto Recycling USA-MA(Lancaster) 1-866-534-0477
1987
Engine
Porsche 944 check hard hit 212,000 C 010683 $550 Brickyard Imported Cars USA-IN(Brooklyn) 1-800-247-9273 and 1-317-831-2627
1987
Engine
Porsche 944 944- TIMING CHAIN BROKE,CORE,RC 135,000 A J5129 $450 Jack's Used Cars and Parts USA-MA(North-Billerica) 1-888-873-5225
1986
Engine
Porsche 944 (4-) 944-LESS PAN RONNIE L1168 $370 Auto Parts of Shelby -PRP USA-NC(Shelby) 1-888-597-7278
1987
Engine
Porsche 944 KNOCKS 000830035 $350 Exit 30 Imports USA-TX(Alvarado) 1-817-790-2992
1985
Engine
Porsche 944 1-6-3BT P19265 59142 $Call Medford Auto Wreckers USA-NY(Medford) 1-631-289-1772
1986
Engine
Porsche 944 12-05 88124 $Call Medford Auto Wreckers USA-NY(Medford) 1-631-289-1772
1986
Engine
Porsche 944 STD,4CYL,GOOD 12-15-06 129,733 A P23206 $Call Medford Auto Wreckers USA-NY(Medford) 1-631-289-1772
1986
Engine
Porsche 944 SLIGHT FIRE DAMAGE WIRRING ONL,#2191721 #2191721 $Call Feezle Auto Wrecking USA-PA(Enon-Valley) 1-724-336-5512
1985
Engine
Porsche 944 2-85,2.5L,F5,CORE,BR KN BLOCK 83,730 A 2A1965 $Call Austin Veedub, Inc. USA-TX(Austin) 1-800-282-3119
1987
Engine
Porsche 944 2.5L,F5,CK COND,MAYBE BLOWN H GASKET 87,662 A 2A2217 $Call Austin Veedub, Inc. USA-TX(Austin) 1-800-282-3119
1986
Engine
Porsche 944 10-85,2.5FI,AC,5SP,R WD,CORE ENGINE WG2905 $Call Best Foreign Auto Parts, Inc. USA-CO(Colorado-Springs) 1-800-624-7364
1986
Engine
Porsche 944 11-85,2.5FI,AC,5SP,R WD,CORE ENGINE XC5044 $Call Best Foreign Auto Parts, Inc. USA-CO(Colorado-Springs) 1-800-624-7364
1987
Engine
Porsche 944 944- FROZE M1387 $Call Denaple's Auto Parts USA-PA(Dunmore) 1-800-426-9696
1985
Engine
Porsche 944 START 108,000 A JE228 $Call Mid Island Auto Parts, Inc. USA-NY(Deer-Park) 1-800-414-9726
1987
Engine
Porsche 924 BOTH ENG AND INDIVIDUAL PARTS IN W2335 $Call West Side Auto Supply, Inc. USA-NY(Queensbury) 1-800-331-3105
1986
Engine
Porsche 944 139,000 A 1A4166 $Call Hearn's Salvage Company, Inc. USA-AL(Arley) 1-800-231-2768
1987
Engine
Porsche 944 SHORT BLOCK BURN DAMAGE $Call Hearn's Salvage Company, Inc. USA-AL(Arley) 1-800-231-2768
1987
Engine
Porsche 924 RB41701 CORE 4715P $Call Oklahoma Foreign European USA-OK(Moore) 1-800-462-2446
1986
Engine
Porsche 944 JP69214 CORE 173,571 2055P $Call Oklahoma Foreign European USA-OK(Moore) 1-800-462-2446
1986
Engine
Porsche 944 RB41527 BENT VALVES.CORE 3428P $Call Oklahoma Foreign European USA-OK(Moore) 1-800-462-2446
1986
Engine
Porsche 944 JS60709 CORE 6066P $Call Oklahoma Foreign European USA-OK(Moore) 1-800-462-2446
1987
Engine
Porsche 944 JP69188 CORE 3432P $Call Oklahoma Foreign European USA-OK(Moore) 1-800-462-2446
1986
Engine
Porsche 944 PARTS ONLY 325 $Call J.C. Recycling, Inc. USA-CT(Meriden) 1-888-247-1199
1987
Engine
Porsche 924 2.5,924S BROKE PARTS 2A0915 $Call Connellsville Auto Salvage USA-PA(Connellsville) 1-877-846-0246
1987
Engine
Porsche 924 core engine 5076 $Call DC Automotive USA-NC(Rocky-Mount) 1-800-579-2410
Razorback1980 11-20-2007 07:13 PM
...a couple more places:
1987
Engine
Porsche 924 7578 $Call DC Automotive USA-NC(Rocky-Mount) 1-800-579-2410
1986
Engine
Porsche 944 *NON TURBO,8V,2.5L-LONG BLOCK 5659 $Call PorFor Auto USA-CA(Los-Angeles) 1-323-589-2162
1986
Engine
Porsche 944 2.0L,AT,OUT OF TIME 163,000 A B23452 $Call Craig Automotive Foreign USA-MO(Rosebud) 1-800-992-1918 1-573-764-3385
1987
Engine
Porsche 924 CORE RAN GOOD,BLOCK HIT C430 $Call Goldies Inc. USA-MA(Walpole) 1-508-668-7450
1987
Engine
Porsche 924 2.5,A.T 100,000 A C05089 $Call Joe's Auto Wrecking USA-NY(Mount-Vernon) 1-914-664-7874 / 1-800-322-5637
1986
Engine
Porsche 944 944 ,AT 140,000 A AA0634 $Call EZ Auto Salvage USA-AL(Theordore) 1-251-653-6923 / 1-866-392-6923
1987
Engine
Porsche 924 2.5,FLR,5SP,RWD,POSS IBLE CORE GWJ494 $Call B & R Auto Wrecking - Tacoma USA-OR(Tacoma) 1-888-325-8469
1987
Engine
Porsche 944 $Call EAP Auto Parts USA-CO(Littleton) 303-922-8397
1987
Engine
Porsche 924 RWD,FI,2479CC,F5,S 007156 $Call A-1 Used Auto & Truck Parts USA-FL(Saint-Augustine) 904-824-0103 / 800-504-1155
Smoker324 11-20-2007 07:45 PM
WOW Razor -- thanks for this info -- one of th elistings is my very own junkyard!
THanks
Porsche-O-Phile 11-20-2007 08:10 PM
I have a complete engine in good shape that I'll sell you for $700 - shipping might be a bit steep going cross-country though.
The "right" way to fix that would be to go oversize .050
Marcone 11-20-2007 08:52 PM
Ive got an S engine that needs a head gasket.. (upgrade time!) haha
Razorback1980 11-20-2007 09:19 PM
Jeff, do you know where you can get pistons after boring? The last I checked they were not available and if they were, they were almost 600 dollars per piston.
marky522 11-21-2007 06:07 AM
Not to mention the huge expense of having it bored properly.
Mark
jmd_forest 11-21-2007 08:05 AM
RE: Toasted Block
Have you considered sleeving the engine? I'm not intimately familiar with rebuilding these engines, however, I have rebuilt a few foreign car engines with good results. I had a BMW 325 that I bought whacked in the front. The collision drove the water pump shaft right through cylinder #1. I had a local machine shop sleeve that 1 cylinder (about $125), found a used piston from a BMW performance shop for $0, honed the remaining cylinders and reinstalled the remaining pistons, and ran that sucker for 9 years and over 220K miles.
jmd_forest
legion 11-21-2007 08:36 AM
jmd_forest,
I assume you are talking about dry-sleeving. These engine don't handle that very well with the already-thin cylinder walls. I have seen them successfully wet-sleeved though. (Much more $$$$.)
jmd_forest 11-21-2007 09:14 AM
Chris,
Sorry for the lack of detail. This was almost 20 years ago (86 325 I bought in 88 with 14K miles on it) and I'm not that familiar with the actual machining of dry vrs wet. I simply stripped the block and took it to a machine shop. They bored out cylinder #1, hot pressed a metal "tube" into the cylinder, rebored the new "tube" to the piston diameter (I gave them the used piston I picked up from the performance shop so they could match the piston to the bore.) I reassembled and drove for the next 9 years
Smoker324 11-21-2007 10:36 AM
I am considering all options,
Dry sleeve, Wet Sleeve (Darton), Nicom plating, bore and oversize pistons, new long block.
One question is about the dry-sleeving. I understand that many have heard that they are problematic due to expansion rates of aluminum and iron.
What about real word -- who has seen dry sleeves move, fail or otherwise screw the pooch?
-Dan C.
Razorback1980 11-21-2007 06:42 PM
There are ways to sleeve the motor (sort of) where the cut out the complete cylinder and put in a new one....great solution...again very expensive. the resleeve process is over 1000 dollars and then the sleeve isn't alusil any longer and you have to buy new rings and pistons. The new sleeves are stronger than normal cylinders and can run really high compression ratios though....great for a supercharger or turbo setup to increase the horsepower but then you have to worry about the bottom end as well.
