Send a message via AIM to hpaulb
Ignition Lock repair
Saw the process in Clark's garage for removal of the switch assembly but it didn't show how to take the lock cylinder out of the column shaft cast piece. Can anyone tell me. Pictures preferred. My key sticks so I was hoping to find out if it can be repaired without replacing the with a new key/cylinder.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 11-20-2007, 06:03 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Cylinder removed....iirc put the key in it and turn and pull the tumbler out.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-20-2007, 06:40 AM
Just went to VW dealer. Service guy marked the spot and said to drill 1/8" hole to access pin to push in to release cylinder. Can anyone verify. See picture attached.
98 BMW 740i
Old 11-20-2007, 11:26 AM
Guy said 1 cm up and 1 cm over from edge?
98 BMW 740i
Old 11-20-2007, 11:27 AM
In the Fires of Hell.....
kdjones2000's Avatar
Someone recently mentioned that there was a casting dimple or simliar in the location that you needed to drill.
I have not done it, so can't help beyond that.
Cheers,
Keith
Old 11-20-2007, 02:47 PM
Anyone?? Before I start drilling holes!
98 BMW 740i
Old 11-21-2007, 09:12 AM
Anyone before I start drilling?
98 BMW 740i
Old 11-21-2007, 10:56 AM
924Sman's Avatar
I wouldn't and never had to. VW is different so I would not use that info, just my opinion.
Dal
Old 11-21-2007, 02:11 PM
OK guys. I'm waiting patently for some help. Someone has done this before. I can't be the only one. I don't want to randomly drill holes in the casing. There is no dimple of mark. I only have the marker mark the VW service guy put on. See above picture. I have no idea if the guy knew what he was talking about. The casting is expensive so I don't want to wreck it.
I would prefer to remove it and see if it can be repaired so I don't have mismatching keys for the car.
98 BMW 740i
Old 11-22-2007, 10:01 AM
Eldorado's Avatar
remove the electrical portion..
here's a pic of what you're trying to remove.. it looks like it might even "pull out and twist".. but i'm not sure on this..
maybe give frank at porschapart a call and see if he's familiar with how to remove it?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-22-2007, 11:08 AM
Found the document in volumm 4 page94-5 but the lock assembly looks completely different. Drilled the hole as specified and nothing. There is no release pin below. Were is the correct spot????
98 BMW 740i
Old 11-22-2007, 11:31 AM
Just got updated with the picture Kyle. No thats for the electrical switch. Remember I repaired yours. I'm taking about the lock tumber assembly beneith.
98 BMW 740i
Old 11-22-2007, 11:33 AM
Politically Incorrect
onZedge's Avatar
Since you already have the assembly out, take it to a locksmith.
Edek
'87 924S
'91 535i
Old 11-22-2007, 12:05 PM
924Sman's Avatar
If it is the tumbler you want put the key in and turn it one click and pull it out at the same time. Did you try it!?
Dal
Old 11-23-2007, 07:56 AM
The lock does not come out on it's own in any position. Iv'e never seen a lock that did. They all seem to have a pin somwere that holds the assembly in. See the picture above. It has a VW part number and simble on it so I would think that they made our lock asseblies. It's the same as the one in clarks garage that shows the process for removing the electrical portion of the switch. If anyone has the lock tumbler ass embly like the one shown above with the two keys, tell me were the lock pin is.
98 BMW 740i
Old 11-23-2007, 01:37 PM
onZedge's Avatar
With the key in, did you try pushing the steering wheel lock pin in towards the tumbler?
Edek
'87 924S
'91 535i
Old 11-23-2007, 04:17 PM
Yes, this has all been tried. Locks don't work that way. There will be a retainer pin somwere that required a drilled hole to access. This is what I need some information on. A lock smith will help once the tumber assembly is out but he won't know how to get it out. If I can't get any help here, then all I can do is purchase a new lock and see were the pin is.
98 BMW 740i
Old 11-26-2007, 06:25 AM
Eldorado's Avatar
have you tried calling Frank at Porschapart or the guys at whaletail?? they may be able to give you guidance on how to get it out..
Kyle
Old 11-26-2007, 08:33 AM
OK finally got someone with the information on clarks. So this is the final post for technical information to help others. See attached for the drill location. Did this this morning and with a punch or whatever, removed the lock. DW40 and an air compressor, add some grease and seams to be ok. Will reinstall and see if it will be ok or have to replace the tumbler assembly.
98 BMW 740i
Old 11-29-2007, 09:24 AM
