runs lean when cold
My car runs lean (have an A/F gauge) when it is cold outside (below 32). Runs poorly then like a flick of a switch it runs great. The colder it is the longer it seems to take.
I figured it is either the temperature sensor I in the AFM or the DME temperature sensor in the block. Could anything else cause this condition? What else controls the fuel mixture? Checked the DME sensor per clarks garage with outside temp at 55F, It read 4.1K. Did not check it after warming because I dont have a problem when it is warm. Havent yet checked the temp sensor I in the AFM. Is this replaceable? Or do I just buy another AFM. Thanks |
what about the Throttle body enrichment switch?
Anyone......anyone.......Bueller! |
sounds like your o2 sensor is taking some time to warm up. as they age they take longer to do this.
You may also want to check the Auxiliary Air Valve is working right or not.
These valve provides an extra air for Air/Fuel Mixture when the engine is cold. |
I dont think my car has an Auxiliary Air Valve. I think thats just the early cars, mine is an 87.
http://forums.pelicanparts.com/uploa...1196721820.jpg Am I correct in thinking that G is the cold start valve? |
Then, it is Idle Control Valve which is similar to Auxilliary Air Valve. It maintains and adjusts the speed whether the car is cold or hot.
Find out if it is dirty or defective. Chances are it will get dirty if you have an AC. |
Thanks,
I'll take it out and clean it up see if it helps. Any idea on how to ohm it out to check it? |
What about the Temp valve (G in the pic)? How does that affect the Shutoff valve (H)? Any ideas? Thanks for the help! |
Thats kinda my thoughts too, thanks I'll give it a try.
I was also thinking about hooking up a 5K pot on the leads for the DME temp sensor to rule it out completely. |
Don't worry about the 5k just disconnect the sensor and run the engine cold. You should be able to tell if it is better within a minute.
| All times are GMT -8. The time now is 08:03 AM. |
