What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Tires in cold states
This is not necessarily a 944 question but..
I have lived in California since 1959. I have driven in snow only 2 times. One of my daughters moved to Chicago and just bought her first car. This morning she found one of her tires flat, supposedly from the effect of the cold on the tire. Does this really happen ? or should she be looking for a puncture or a leak?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 12-09-2007, 01:43 PM
Glorified Babysitter
BeerBurner's Avatar
Has there been a dramatic temperature drop over the past two weeks?
I'm hard-pressed to believe that a properly-inflated tire would suddenly go flat overnight because of the cold, unless there was a significant drop in temperature. Plus, if it got cold enough to make one tire go flat, the other three would go as well.
It's possible that the one tire was already underinflated and this just finished it off, or maybe someone was bored and let the air out. However, I'd recommend looking for a puncture.
BB.
'87 Porsche 944 (toy)
'90 Miata (daily driver)
'04 PT Cruiser (her's)
"Sometimes you're the windshield... sometimes you're the bug."
Old 12-09-2007, 02:28 PM
Send a message via Yahoo to bobp53916
I have lived in ND most of my life and every winter the tires seem to lose some pressure. Dont really know the reasoning behind it and never bothered to check into it but it does happen.
1985 944 N/A
1992 Formula Firebird (sold)
1997 Sebring LXI
1998 Ford Expedition
1983 944 (parted out) 1979 924 Turbo (sold)
Old 12-09-2007, 04:13 PM
meister member
speedracing944's Avatar
The cold decrease the volume of air inside the tire (the mass remains the same). A properly inflated tire should only lose a couple PSI due to the cold weather. If her tire is flat there is more going on.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-09-2007, 05:04 PM
Yeah, I’ve seen it up here in WI, probably a bad/weak seal at the bead (aluminum rims corrode from the salt). She could have them broke down and sealer applied.
Rick
93 968 (My summer car),
05 Cayenne S (My winter car),
79 924 (Wife's summer car), 02 C230k (Wife's winter car),
Old 12-09-2007, 05:32 PM
Eldorado's Avatar
although it was cold outside, it was just *really* cold on one corner of the car, causing just one tire to go flat..
heeeeere's your sign..
anywho, cold temps will cause a pressure difference... not a flat tire... especially not just ONE flat tire.. something else caused it to go flat.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 12-09-2007, 06:24 PM
Aufenbahn's Avatar
+1 on 968rz - I was driving thru nebraska on the way to Colorado once a few years ago and after stopping for a meal late at night when the outside temp was below zero F. we started back driving and immediately had a flat. putting on the spare in the cold was not pleasant and when we got back to the truckstop they could find nothing wrong with the tire and so reinflated it and off we went. It never caused a bit of problem the whole rest of the trip. Its something about the extreme cold affecting the seal between the rubber tire and the metal rim. I don't know if its the rubber getting less rubbery in the cold?
Andy D.
Currently driving 2005 Audi A4
Currently driving 1998 Grand Cherokee sometimes
Old 12-09-2007, 07:01 PM
earlr85944's Avatar
extreme cold can make you lose 20lbs easy from summer temps, an already low tire can go flat as stated above. its just the mass of the gas....
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 12-09-2007, 07:17 PM
Eldorado's Avatar
it seems like this was a rather sudden problem though..
how long between the time she purchased the car, until it started getting cold?
what do you consider cold? -5C? -10? it hasn't reached much beyond -10C here - and that's not too cold if she's experiencing similar temps down there.....
Kyle
Old 12-09-2007, 07:29 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Like by flat do you mean FLAT? Or just really low? There's a difference.
My snows on my Subaru went down about 15 psi over night once. I could see that happening. But that happened to all four, not just one.
I'd check for leaks or punctures though because thats strange that it happened to one tire, and that it happened so much and so quickly.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 12-09-2007, 07:38 PM
Thanks all. I'll let you know the outcome..
3-924's (Sold)
1967-912 (Traded)
Old 12-10-2007, 01:10 AM
Misunderstood User
Winter has come to the Chicago area with vengeance. It seems we went from late September to winter within the last 2 weeks. It was cold a couple of days and there is snow on the ground. It has been in the upper 20's - low 30's during the day and in the 'teens' at nite.
Yes you do lose 'air' in the winter. Having said that; a tire going flat due to cold weather, I haven't seen it. I don't consider 20's and 30's cold either. Sub zero or low 'teens', that's cold.
One of two reasons already stated: a bad tire seal or a puncture.
Air contracts as the temperature gets cold; the molecules contract. It also expands in the summertime. You now see places like Costco or NTB that offer Nitrogen instead of air. It is more stable than air and it doesn't retain moisture (water).
Moving from CA to Chicago? Shouldn't it be the other way around. Winter will be an adventure for her.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 12-10-2007, 07:16 AM
gtroth's Avatar
FWIW--good friend of mine from Chicago told me that it's widely known there that you shouldn't add air to your tires when they are real cold since moisture in the valves freezes and causes leaks. Maybe that's what happened?
1995 993C4 guards red
1988 944S alpine white
Old 12-11-2007, 10:35 AM
Misunderstood User
gtroth is correct. I have seen that happen too. Air can retain water. Water can rot tires, cause rust on the seal area and other fun stuff.
Jim
1983 944n/a
Old 12-11-2007, 12:07 PM
unindicted co-conspirator
looneybin's Avatar
The PSI rating on your tires is for cold tires.
As the rubber heats up from driving the air inside them expands & the PSI increases - likewise, when cold, the air inside contracts & the PSI decreases.
Nitrogen is not suspectable to this thermal expansion/contraction & is now being used by most tire shops.
++ on the moisture in the air freezing & causing the valve to stick
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control
'86 944 - Wilks PP2, strut brace, harness bar, M030 sway bars, 200# springs, koni adj, throttle cam, K&N filters, momo wheel & shift knob - faster in the twisties than a mustang
Old 12-11-2007, 12:20 PM
jackpine savage's Avatar
Valve stem o-ring. Temps have decreased tire pressures approx. %10. We've had single digit (F) temps just 100 miles from Chi-town, and below zero a few nights.
More than likely the pressures were too low to start with. Just a guess here; should have been 40 psi but were at 30, then dropped to around 25-28? Or, the valve stem is shot in that one tire. Or, she picked up a nail/screw?
However, in the windy city you'll easily find a shop to replace the tire, wheel, and front end suspension for around $2500.
When in doubt,
don't part it out.
Old 12-12-2007, 12:01 PM
Banned
nota's Avatar
it is NOT any magic in Nitrogen
just no [or very little] oxygen or water
normal air is already 70+% Nitrogen
BTW what the heck is suspectable??
N2 sure will expand or contract in changing temps
temp/pressure gas law is not very effected by gas type
heat any gas and the pressure goes up
now water liquid [ cold ] vs vapor [ hot ] does have a BIG effect on pressure
Old 12-12-2007, 07:16 PM
looneybin's Avatar
Ok so i didn't spell check, don't flog me
Nitorgen is just more stable than air because of the larger molecule & doesn't migrate thru the rubber as fast.
I must have been asleep in thermodynamics class during the gas pressure demo.
Old 12-12-2007, 07:41 PM
Finally got her to call me back. Problem was two fold. She had a nail in the tire that had broken off and the rim itself was bent to the point that it was leaking air. SHe had to replace the tire ( no rubber left) and got the rim bent back . All that for 85.00 in the windy city. This also cured a vibration in the front end.
The dealership also provided nitogen for all the tires.
Thanks all.
3-924's (Sold)
1967-912 (Traded)
Old 12-20-2007, 12:41 AM
