PRMN944
Car runs sluggish after full tank of gas
Whenever I filled up my gas tank on my '83 944, the car does not accelerate well or very sluggish performance.
When gas tank near empty, the car runs better.
I do not seem to understand these problem. Does anyone ever replace the fuel screen inside the fuel tank ?
Old 11-29-2007, 02:03 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
May sound like a simple minded answer but 1 gallon of fuel weighs 8 pounds...IIRC, take that times 14 gallons and you have added a whopping 112 more pounds to pull! This is the least expensive advice you will get to increase HP usage!
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-29-2007, 06:32 AM
Quality
phoenix_iii's Avatar
Weak fuel pump can't perform well under pressure? ... That's even weaker than 924Sman advice... but may also be valid?
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 11-29-2007, 07:11 AM
mr. dude's Avatar
You might want to check your fuel filter.
2006 Porsche Cayman S
2006 Lotus Exige (Sold)
1986 Porsche 944 (Sold)
1981 Porsche 931 (Wrecked)
1987 Porsche 944 (Sold)
Old 11-29-2007, 07:37 AM
bearone2's Avatar
Dal
a gallon of water weighs 8 lbs, a gallon of gas weighs 6 lbs.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-29-2007, 08:29 AM
PRMN944
I remember when I check the fuel pressure, it was at the right range.
Perhaps , I should recheck the fuel pressure when the gas tank is full.
Thanks for the fuel pump and fuel filter inputs.
Old 12-03-2007, 01:35 AM
924Sman's Avatar
Ok 6 lbs. then, thanks.
Dal
Old 12-03-2007, 04:44 AM
DarylJ's Avatar
Send a message via AIM to DarylJ Send a message via Yahoo to DarylJ
Just a shot in the dark, but try driving around with the gas cap off. Maybe you have a vapor lock issue and just need a new cap.
Daryl
85.5 944 Status:
[ ] running [X] broken
Old 12-06-2007, 07:25 AM
924Sman's Avatar
After some thought, it could very well be the check valve in line of the FP.....?
Dal
Old 12-06-2007, 07:28 AM
moorepower's Avatar
My guess is that it's a tank venting problem. If it was a pump or filter issue, I wouldn't think it would matter if you had a full tank or empty. Like Daryl said, try driving it without the gas cap and see if that helps.
Dan
Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc.
Old 12-06-2007, 08:47 AM
924Sman's Avatar
I agree^^ but the best answer is it could be anything!
Dal
Old 12-06-2007, 08:58 AM
moorepower's Avatar
Yes, it could be anything, but it definitely is something. ....... Well, that's just a guess, anyway.
Dan
Old 12-06-2007, 09:46 AM
PRMN944
I bought a new aftermarket gas cap from GI 'S Joe last year . It was non locking type.
Old 12-09-2007, 12:33 AM
DarylJ's Avatar
Fantastic reason to take it off and try what I said. I don't trust aftermarket parts. I use them, but I don't just accept that they're always OK and to spec.
Daryl
85.5 944 Status:
Old 12-09-2007, 08:05 AM
PRMN944
Please allow me to apologized to all fellow 944s for not getting back to the thread soon.
Just did not have the extra time .
Anyways, I jus t replaced my fuel filter and done fixing the leaking oil cooler.
I will get the OE gas cap and probably an oxygen sensor too since this old tired
944 is acting bad now because it is very cold in Portland.
Old 12-14-2007, 11:47 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
You might want to look at the type of "gasoline" you are using. These cars do not do well on corn blended fuel. I recently changed back to Chevron due to my cars inability to use the cheaper fuels. I checked with the local Porsche dealership.
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 12-15-2007, 02:40 PM
PRMN944
In the past, I used Shell sometimes 76. But, currently using Chevron 89 grade.
Where I live now , from November through February the gas stations mixed Ethano with the
gas.
Old 12-15-2007, 10:54 PM
