father and son
Tunnel insulation
Does anybody know where I could get the foil insulation that is used on the firewall and tunnel or a suitable substitute.
Old 12-17-2007, 08:11 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Not sure I know what you mean, but if you want something that will keep the heat down some and keep things quieter you can use dynomat or fatmat. both can be found any any stereo shop or online. dont recomend putting it in during the winter though. When it's the middle of the summer & blazing hot is when it's best to put this stuff in. but it is easy to do.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 12-17-2007, 08:20 PM
Nobody Special
Don't get either of those products near a hot exhaust, especially a 951. They are asphalt based and flammable. It's much better to use a heavy foil-faced insulation designed for the application that can take the heat. I've used this stuff several times and suggest it as a safer more effective solution.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=THE%2D14100&N=700+400356+115&autoview=sku
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 12-17-2007, 08:29 PM
Proprietoristicly Refined
John_AZ's Avatar
Thanks 2Tight,
I changed my clutch in October and tore some corners off. I used a painters mask to avoid breathing the fiber particles.
John_AZ
1988 924S + 1987 924S
Old 12-18-2007, 06:32 AM
fast924S's Avatar
Send a message via AIM to fast924S
I used this heat sheet stuff. It take some time to cut the stuff to fit but it works
Not finished yet
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 12-18-2007, 12:56 PM
