LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
kayw's Avatar
Send a message via ICQ to kayw Send a message via AIM to kayw Send a message via Yahoo to kayw
944S2 oil in coolent
HI,
Recently I find oil mixes into coolent. I search the forum that somebody talking about the oil cooler seals. Does 944S2 (89's) has oil cooler seals? If so, where is it located?
Besides oil cooler seals, any possible bad things? Such as head gasket, oil-water exchange (Does my carhas this also?)
Thanks very much.
Kay
Porsche 944S2 (3.0L, NA) 1989 -- rare in Hong Kong
Old 12-15-2007, 05:57 AM
The 944S2 has the same housing as the 944, just not the heat exchanger, look up the Pelican parts diagrams and you will see. They sell all the parts you require to replace the seals.
Head gasket is a possibility but not the first choice.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-15-2007, 12:48 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
oil in the coolant will not be the head gasket. if you had coolant in the oil it would be the headgasket, but not the other way around.
Replace the seals. It's a pain to do & messy, but relativly easy.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 12-15-2007, 12:57 PM
Luis de Prat's Avatar
Do not drive the car until you replace the oil cooler seals. Empty the coolant and replace. The oil in the coolant gums up the waterpump and if you drive the car with the milkshake, you'll have a failing waterpump sooner than you'd like!
Old 12-15-2007, 01:06 PM
kayw's Avatar
Hi,
Thanks for reply. I don't see watch in the oil. Hope it is not head gasket problem.
So, I would go for seals.
When replace the seals, besides coolant, do I have to drain the oil too? (I just have oil change... )
As I see the project list, what I need is just 2 seals on both side, right? Hope anybody can share the experience.
Thanks!!
Kay
Old 12-19-2007, 10:19 AM
You need this item from Pelican: 10-0914-165-M30
You should use this item as well if you dont have it: PEL-TOL-P218
It is best to drain the oil on this job & replace the oil filter. Draining your oil will also show you if it is milkshake as well.
It is possible that the oil cooler itself has gone bad or got a leak. Follow these steps for testing the oil cooler: http://www.clarks-garage.com/shop-manual/lube-10.htm
This is the process to replace the seals: http://www.clarks-garage.com/shop-manual/lube-01.htm
Clarks-garage shop manual is the best there is for many of these kind of items.
86 Metallic Grey
Old 12-19-2007, 11:55 AM
The M44/41 (S2) engine does not have the heat exchanger like the 8V 944NA. It has a seperate cooler.
Old 12-19-2007, 04:48 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Follow the advice of Britwrench...it will serve you well.
MOST DEFINITELY HAVE TO CHANGE THE OIL. It's already been mentioned that this can cause some water pump problems but that's not the most serious. Coolant will eat up your rod and main bearings. Do not run this engine with coolant in the oil. Change it immediately and run some oil flush through it and change it again fairly soon. You may lock up your engine if you don't do this. Oil is cheaper than a new engine.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-19-2007, 07:20 PM
kayw's Avatar
Hi,
Thanks all your helps!
I am going to order the Complete Gasket Set at Palican. I hope it is not a big job -- I can do it by myself in New Year ....
From the diagram, I also see there is an Engine Oil Cooler, which costs US$466
Is it possible of leaking / broken on this $$$$ parts too?
Thanks.
Kay
Old 12-20-2007, 02:41 AM
