944 fuel pump problem
Hi everyone my fuel pump it was not working y check the wire line there is not power anyway the fuel was bad i changed the fuel pump Fuel filter and DME relay and the fuse too when you turn the switch there fuel pump doesn't work and no power what may be the problem I have a Porsche 944 year 86 non turbo and the fuel box is at front there is any other fuse box inside the car please help me
Old 12-23-2007, 03:53 PM
Hi, you will only get voltage to your fuel pump when you are turning over the motor with the starter. Have someone crank over the engine and you with a volt meter see if you are getting 12 volts to pump. This is where I would start.
Old 12-23-2007, 07:19 PM
