Directional/Hazard problem
Hello all, I have a 1984 944. My problem is that my directionals and hazard lights dont work. I checked the fuses ans relays and I am getting power to both of them. I did recently drop the fuse/relay panel to fix my fuel pump relay socket. That was a succuss, but when I tried my directionals, nothing. They did work before dropping the panel. But I am getting power to the fuse and relay! This is where I am stumped!! What is the proper voltage on the relay? Could a ground have come lose? I don't get it!! Thanks in advance for your help!
Old 12-08-2007, 12:36 PM
still trying!! No luck as of yet. Anyone?!!!
Old 12-26-2007, 02:47 PM
That Guy
Techno Duck's Avatar
What exactly is wrong with the directionals, dont come on? I would try replacing the relay as they do go bad over time. Typically a failed relay will cause the directional and hazards to stay on without a pulse.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-26-2007, 03:40 PM
Directiontals/hazards don't come on at all outside of car, light goes on inside car without pulse. Relay is relatively new. I'll keep trying!!
Old 12-26-2007, 04:30 PM
That Guy
If the green light on the gauge cluster comes on solid, try replacing the relay. They are cheap and available from any autoparts store.
Jon
Old 12-26-2007, 04:52 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Check the lamps and clean the switch assembly is another to do. Wipers work? Come on with out you turning them on ever?
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 12-26-2007, 05:05 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
I 2nd the part about if the wipers work or not. If they dont then the problem is at the assembly or you have a connector disconnected.
What do you mean though that your getting power to the relay & fuse? Since you pulled the fuse panel, start there.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 12-26-2007, 08:39 PM
