Will early doors fit an 87 NA?
Will an 83 NA door fit and 87 NA? In the past some said that they will and others have said the late models are different. Anyone know for sure? Thanks.
Larry
87 Guards Red 944-NA |
Certified Rennwerker
Yes......part#OEM-94453100606GRV.........difference is in the mirror mount with or w/o.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Thanks Dal,
This is a shell no mirror, no handle, not sure about the glass. Is it possible to use the parts from the 87 door on the 83? Sounds like it won't be a direct swap of parts. Thanks. Larry
You are fine, go for it! Handles amd mirrors are all the same except the 968's. Glass assembly is also the same, the inner panels are not however, early interior vs. late interior but still will work. Now get that door on!
![]() Dal
the wiring harness may be different (square plug late vs round plug early) but you can transfer all the parts from one to the other.
