Interor Lighting List
Hello everyone,
I was wondering if anyone has a list of the bulbs needed for the interior lights. I can not find my manual and looked at a few places on line, but can not find the list. I figured someone might have a PDF or other document with the info. I am looking for the list of bulbs needed, for dash, ash tray, glovebox, defrost adjustment etc. I am looking at replacing all the lights inside, due to old dim bulbs want to get some brighter ones. Thanks for the Help, Mike |
Hey Mike,
If you haven't already, go check out Clarks-garage.com. There is an excellent procedure on there for upgrading your dash lights and the reflective cover behind them. I don't remember the bulbs I used but am pretty sure you will find it there. Pretty easy upgrade well worth the time it takes. Good luck! |
Ichecked out Clarks, I am going to do that up-grade when I chenge the lights out. I was needing a p/N; list of the bulbs needed to replace all the lights inside, I could not find that on Clarks, I know I saw it in my Owners manual, but I can not find that, and it is not in my Haynes. Thanks Mike
this link has the instrument panel light part number:
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_ELlite_pg4.htm#item17 |
did those links work for you?
It helped me to find a few of the lights, here is a list below of the P/Ns:
OEM-99963113090 – Bulb, 0,30 W – Bulb inside light selector knob OEM-94464190000 – Bulb – Digital Clock 999-631-018-90-M97 – Bulb for Interior Light, Between Visors, and trunk 900-631-115-90-M97 – Bulb for Engine Compartment 900-631-019-90-M97 – Instrument Bulb X3 Plug-in Type OEM-92864198300 – Instrument Bulbs X6 Turn signal, Oil etc Now I need to find the bulb P/Ns for the following: Ash Tray Light Defrost Vent selector in the middle of the dash Thanks for the Help, Mike |
not sure by what you mean by Defrost Vent selector in the middle of the dash. i'll keep looking though
| All times are GMT -8. The time now is 08:19 PM. |
